Wasted spark problem SHE BLOODY RUNS!!!!!!!!!!!
#121
Evening Pal,
Sorry,l been out the later half of teh afternoon maping with Kenny to get a fellas car ready as he needs it for tomorrow.
I honestly think that for some reason your chip isnt working, OR the wasted spark driver isnt working. Incredibly rare but it happens, we are sadly only human.
My first thoughtm, is who on here can loan him a chip? Any chip, std, greys, whatever, it will at least make the car start and confirm a software fault. If thats teh case i will send you one SD Monday and the problem is solved.
Second possibility is extremely unlikely, but again, possible, check the orientation of teh chip is correct, and also that teh daughterboard is plugged into teh motherboard correctly. If you give me your number i will explain to you if required.
Sorry i cant be of any more help long distance.
#129
Originally Posted by boy_racer2f2f
i know im not much help, but would just like to say well done to the members on here who are trying to help this chap out. its what passionford is all about
Tim
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
Tim
Stu, you did say to me the other day that you hadn't had one go wrong yet
#132
Tim
Tim
ive just goto clean a connection between the new coilpack loom and old loom which looks a bit shitty but otherwise i cant see anything else.
cheers for all the help guys keep everyone updated
#134
Check the chip as soon as you can mate.
Also worth unscrewing the daughterboard and trying it with the ribbon cable orientated differently as these have been known to get intermittent contact. I can send you another chip on Monday for before 9am Tuesday delivery if you wish, just let me know pal.
#140
Stu, I have none of the experience the others have. But when you installed the wires onto the pins you didnt get them too hot did you?
It hasnt melted solder and shorted other circuit tracks or any thing silly??
#143
Ok, this only leaves the WS Driver mate.
If i was you i would post that ECU back at 9am using royal mail special delivery and i will install a new wasted spark driver for you and have it back with you for special delivery Thursday and teh car can be up and running for easter weekend.
Sorry for this inconvenience Pal, but sadly we are still humans and can occasionally slip up from time to time.
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
#149
still struggling with this.
you mentioned the injectors clicking etc, which was symptomatic of a dead ribbon cable, as mine used to click when i fitted my new chip, a new baby board soon sorted this.
whats the advantage of the wasted spark conversion? been thinking about this for a while now
#155
recieve ecu back this morning cheers stu!
but guess what stilld ont work
even tho it dont spark like mad now when ignition is on just dont fire up!
so this rules out any ecu probs
i honeslty cant see what it can be now?
looks like RR day is out the window and ill have to see if "the original" will come give his opinion
#158
Hi ...I'm sorry to see that you have problems with it.....!
I'm in the middle of doing a coilpack setup on my car too, And I would like to ask if you have done a tachometer mod to your car...??
If so, do you have any pic's of it ??....as I have some trouble doing it
#160
Originally Posted by Roosie
i havent done anything to the clock just yet tbh as im trying to get it sorted first!
how do i test if the amps are working fine? i dont know if ryan checked this or not on the phone
About your problem,...You are sure that all plugs are mounted correct ?
About the amps....I dont know
