Wasted spark problem SHE BLOODY RUNS!!!!!!!!!!!
#41
PHONE Stu / Kenny
"It's worse than we thought!"
Originally Posted by Roosie
UPDATE
when i put ignition on but not turn it the spark plugs spark like mad constant then when u turn it over there is a weak spark
#45
Originally Posted by white4x4cos
you forgot to take out the supressor in the green wire as mentioned
This can cause fatal damage to the coilpack driver
Roosie, do you have a voltmeter and know how to use it ?
#46
yes the supressor needs to be removed and connect the 2 green wires.
Don't think it's going to work,this has to be done before instalation see step 1A
#47
#48
#57
it did on mine
#59
i done it before i even started car for first time didint work so i put it back to original.
symtoms are!
my spark plugs start sparking when i turn on ignition sometimes fast spark sometimes slow!
My fuel pressure refulator is always hissing when ignition is on
even now and there is a little hicup were it seem like it want to start but very slightly
symtoms are!
#67
WTF - No dash lights ?????????????????????
The ecu unplugged should not affect any dash lights - Dont understand that. !
The car has been running before you did this ?
Does it have an imobiliser and is it disabled ?
#79
I dont think its the coil but try it anyway to eliminate it.
The earths are on the loom on the inlet manifold.
2 or more large brown wires.
Follow the loom back from injector 1 until you find them.
As you have changed the injectors, it is possible you MAY have disturbed
them or unbolted them without realising.
Double check everything again.
If the dash lights dont work you have other problems !!!
