Alternator question
Old Mar 30, 2007 | 12:16 AM
Billy_RS's Avatar
Billy_RS
Default Alternator question
I've swapped to efi on my erst. Because i needed to put the cps on, i got a sierra 1.8cvh bottom pulley. Now then, the belt from the sierra is different and im stuck on what to use/do with it?
Any help would be great.
Old Mar 30, 2007 | 12:24 AM
xr4x4rs's Avatar
xr4x4rs
if yor using a sierra bottom pulley then you need to get the sierra alternator pully and swap them over
Old Mar 30, 2007 | 10:47 AM
Billy_RS's Avatar
Billy_RS
OK, but what belt should i use because i think the sierra belt is too big?
Old Mar 30, 2007 | 11:03 AM
Rob's Avatar
Rob
What type of belt is it?
You can pretty much walk into any motor factor and say you need a particular type of belt and specify the length and they will get belt you need.
Old Mar 30, 2007 | 11:14 AM
xr4x4rs's Avatar
xr4x4rs
it will be a multi groove belt
you need tgo get a bit of string and wrap it round the pulleys very tight so its under tension
then you need to go to the local factors and get one the rough size of the string
from then its trial and error so expect to go back to the factors until you get the rit one
may get away with a belt the same size as a cvh one but int multi groove
Old Mar 30, 2007 | 11:57 AM
Rob's Avatar
Rob
Some belt manufacturers list inner diameter some list outer diameter and some list both. Depending of how much you can lose from tensioning
For multi poly-v belts most part numbers will be..... number or ribs, (i'm guessing at 4 or 6 for alt belt??) and then the length (ie 1200mm) so as an example 4PK1200.
Can download many catalogues online for the likes of Gates, Dayco etc.... Gates sizes are often listed in inches so are basically K040472 which would be the equivelent part number for Gates.
I wouldn't try Halfords as they can be a bit dense, but most normal factors will have access to decent volumes af parts catalogues.
Old Mar 30, 2007 | 12:00 PM
nigel b's Avatar
nigel b
use the standard 1.8 cvh sierra belt and the pulley on the escort alternator
the alternator might need spacing over slightly
Old Mar 30, 2007 | 02:36 PM
Billy_RS's Avatar
Billy_RS
Have you done this yourself mate?
It looks miles too long for the escort.
Old Mar 30, 2007 | 03:42 PM
nigel b's Avatar
nigel b
yes thats what im using
i turned down the pulley so i can remove it without moving the engine
bolted the 1.8cvh sierra alternator pulley onto the erst alternator
machined the sierra alternator mount so it lines up perfect with the bottom pulley
standard 1.8 cvh alternator belt
Old Mar 30, 2007 | 04:31 PM
Puss2's Avatar
Puss2
Formerly know as Puss
Not the best pics but might help
Old Mar 30, 2007 | 05:33 PM
nigel b's Avatar
nigel b
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
