FAO mr rainbird,rapidcossie or other people with std airbox
Old 28-03-2007, 07:05 PM
capri-rs
capri-rs's Avatar
Default FAO mr rainbird,rapidcossie or other people with std airbox
please post some pics how you have modified the bottom of the box to get more air in
or any other tips and tricks are also velcome
Old 28-03-2007, 09:57 PM
cbp
cbp's Avatar
Just make a larger hole..
Old 28-03-2007, 10:05 PM
rapidcossie
rapidcossie's Avatar
I have no pics but i have cut the full front of the box off.
Also have protected the side from the heat with thin heat shielding metal.
Old 28-03-2007, 10:09 PM
Nash
Cake lover!
Nash's Avatar
Look on Paul Ripley's thread in pics section it show it in there.
rapidcossie
found a pic two secs
Old 28-03-2007, 10:13 PM
rapidcossie
i have also cut off an blocked up normal hole as you get alot of latent heat from rad going intot this.
see the silver sheild thing, its bonded onto back of headlight and makes sure the airbox is only fed with cool air.
Old 29-03-2007, 08:43 AM
capri-rs
capri-rs's Avatar
excellent pics guys
did you cut any extra/larger holes in the bodywork to get more air in??
Old 29-03-2007, 08:47 AM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
PM Franco, he has pictures on his computer of the mods I advised him to carry out on airbox .
Old 29-03-2007, 08:53 AM
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
Does having the standard air box actually make much difference over a cone filter? I have my air box sitting in the garage doing nothing.
Old 29-03-2007, 09:03 AM
Franco
Franco's Avatar
Mine / Mikes Mod
Before
After
Old 29-03-2007, 09:15 AM
capri-rs
capri-rs's Avatar
think you can get cooler air in with a airbox compared to a cone filter.
cant be bad. euan have done 485 atw with one
Old 29-03-2007, 09:18 AM
CossieRich
CossieRich's Avatar
im sure it is good, but has anyone doen a test with a cone filter and then a standard air box?
Old 29-03-2007, 09:20 AM
Franco
Franco's Avatar
Heat soak Rich from the engine bay!
Pure and simple
Old 29-03-2007, 09:22 AM
dovboy
dovboy's Avatar
ean has and the airbox did 30bhp more
Old 29-03-2007, 09:23 AM
Franco
Franco's Avatar
You'll notice Rod does run a filter due to the rather large volumes of air his turbo swallows, BUT.................
He's combating the heat soak by having the filter boxes off in the bay!
foreigneRS
Testing the future
foreigneRS's Avatar
imo there's no point in cutting the box just to suck in more hot air from the engine bay
the box is only worth having if it gets cold air directly from the front of the car before it has gone through intercoolers, radiators etc, and then a cone can also do that if boxed in or placed elsewhere
Old 29-03-2007, 09:25 AM
Franco
Franco's Avatar
Well mine wont be sucking in the engine heat Especially when moving
Old 29-03-2007, 09:29 AM
CossieRich
CossieRich's Avatar
so why would a cone filter be sucking in hot air whilst moving?
Old 29-03-2007, 09:33 AM
Franco
Franco's Avatar
Its sucking air in a complete 360 deg area, so the enignes hot, the turbos hot thus the whole engine bays getting hot.
The filter is sucking all this in, as well as the small amount of fresh air being pushed in from the front.
Airbox is sealed thus only receiving the cold air its being force fed.
Well thats my understanding anyway!
Old 29-03-2007, 09:36 AM
rog
rog's Avatar
That's exactly what i thought???? Surely it only matters when the car is moving anyway, and therefore i would have thought that cold air would be going through the engine bay anyway. So the filter would be better? I'm not trying to piss on your parade by the way, just trying to understand the reasoning of it all.
Old 29-03-2007, 09:38 AM
Franco
Franco's Avatar
What after its passed through a intercooler, Rad........... It would have warmed up quite nicely after that i'd say....
How many times have you ragged it, pulled over, opened the bonnet only to be hit with a wave of heat!
Thats what the filters sucking in!
Old 29-03-2007, 09:40 AM
rog
rog's Avatar
I think we need a test to be condcted!
Air temp, post intercooler with airbox, and one with filter and see the diference, on the same car.
Old 29-03-2007, 09:47 AM
capri-rs
capri-rs's Avatar
who is up for the job then??
NEIL A
NEIL A's Avatar
Because the cone filter will be sucking in the hot air from the engine bay aswell as the air from outside, if you have a airbox with its only inlet ducted to the front of the car it can only get cold air.
Ive ducted mine straight from my headlight into the box, and if that doesnt flow enough i will put a second duct down to my 500 grill for more ram'd cool air.
Some one on here had a good pic of a polaris escos with a modded box with a 4" inlet bonded into the bottom of the box.
Old 29-03-2007, 09:48 AM
Franco
Franco's Avatar
That'll be Kev - Sarge!
Old 29-03-2007, 09:50 AM
NEIL A
NEIL A's Avatar
Euan has done tests at ava and got gains with the box fitted, ava also advised me to refit the standard airbox as it would gain me power.
Old 29-03-2007, 09:52 AM
NEIL A
NEIL A's Avatar
Yip thats who it was Franco, looked to be a good idea might do it myself aswell as the headlight intake.
Old 29-03-2007, 09:54 AM
Stavros
DEYTUKURJERBS
Stavros's Avatar
You think the air under a vented bonnet is boiling hot on a car moving at speed?
Rollers yes. Road? Hmm.
rog
rog's Avatar
We need numbers!!!!
Old 29-03-2007, 09:58 AM
Franco
Franco's Avatar
Well i'll have the best of both worlds when a certain someone pulls finger!
Oh and the R&D will have been done by Boreham on these, so put your money aways lads!
Old 29-03-2007, 10:00 AM
Franco
Franco's Avatar
Stavros
Not boiling hot, but still hotter than the air outside of the car.........But i'd imagine we aint the first to disagree on this subject nor will we be the last!
Old 29-03-2007, 10:09 AM
foreigneRS
Testing the future
foreigneRS's Avatar
i don't think, i know.
i test air con components for a living, both in a climatic wind tunnel, and in field tests (i was in south africa for a hot climate filed test with ford last month)
there are whole departments in car manufacturers dedicated to measuring and managing the underbonnet heat in vehicles
Old 29-03-2007, 10:11 AM
Franco
Franco's Avatar
Smart arse!
Old 29-03-2007, 11:13 AM
pete mcrash
saff is working!!!...atm
pete mcrash's Avatar
so could u...."please dont laff".....tape up the top half of ur cone filter,so it just feeds from the bottom..............
Old 29-03-2007, 11:23 AM
Deleted by Request
Former Sponsor
Deleted by Request's Avatar
...this old chestnut
The air box is as stuffy as a cone and more restricted...i would want more AIR..hence i only choose cone.
Thats why we have a decent intercooler guys to cool that air from the turbo.
Remember the optimum air charge temp is 40c..you will get the best out of your engine at that
Old 29-03-2007, 12:21 PM
foreigneRS
Testing the future
foreigneRS's Avatar
he's off again
so we use a cone to suck in hot air from the engine bay, the compressor then has to work harder and adds even more heat, which we then we get rid of out of the intercooler into the air that is then sucked in - genius
even someone as ignorant as you phil can't argue with physics - cold air is more dense so has the potential for more power
Old 29-03-2007, 12:27 PM
Deleted by Request
Former Sponsor
..my point being its not drastically cooler using the std air box..and what you do gain you loose in air flow...maybe on a wrc car we should be bothered but not or a road car.
PLUS the noise is better and if you dont run a dumper the pidgeons are much louder
Old 29-03-2007, 12:32 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
Franco- Optimuim carbon airbox for what? A WRC car? So quite possibly optimised for their power and massivley restrictive over the level that doesnt matter to them, i dunno, 300bhp?
No its not you clown Good old internet rumour
Anything ABOVE 40degC needs improving on, but 40degC or less is more than acceptable and not worth doing anything much to improve on.
Old 29-03-2007, 12:34 PM
Deleted by Request
Former Sponsor
..Stavros you get the idea burn rate at 40c So aim for that..its fact not rumour
Old 29-03-2007, 12:43 PM
Franco
Franco's Avatar
Oh do shut up you drivelling idiot..............It looks the fucking tits!!
Quick Reply: FAO mr rainbird,rapidcossie or other people with std airbox
