FAO mr rainbird,rapidcossie or other people with std airbox
Old 29-03-2007, 12:46 PM
  #41
foreigneRS
Testing the future
foreigneRS's Avatar
Originally Posted by Bosch Dealer
..Stavros you get the idea burn rate at 40c So aim for that..its fact not rumour
if 40 deg. C is ideal, why is there not some sort of heater for cold days?
think stavros summed it up nicely by calling you a clown
Old 29-03-2007, 12:54 PM
  #42
Deleted by Request
Former Sponsor
Deleted by Request's Avatar
Mate its not me you are calling a clown
..but i do accept it aswell
Its not my fault the internet is full of spaccos as Stavro puts it
Old 29-03-2007, 12:59 PM
  #43
Garage19
Garage19's Avatar
Remember the optimum air charge temp is 40c..you will get the best out of your engine at that
Really???? Where did you get that gem from?
  #44
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
i always thought the colder the air the better, as cold air is more dense. the hotter the air, the harder it is to combust? Is that right or wrong?
So by my reasoning, if the air charge is 30 deg c, thats better for power?
Old 29-03-2007, 01:01 PM
  #45
Chip
*** Sierra RS Custard ***
Chip's Avatar
...this old chestnut
The air box is as stuffy as a cone and more restricted...i would want more AIR..hence i only choose cone.
Thats why we have a decent intercooler guys to cool that air from the turbo.
Do you have an intercooler before the turbo as well then Phil, or do you think it makes no difference to the turbo if its sucking in hot air?
  #46
CossieRich
CossieRich's Avatar
i expect he got it from the fact that most cossies are set to trigger water injection (if you have it of course) at the 40c mark?
Old 29-03-2007, 01:02 PM
  #47
Bullett
Bullett's Avatar
i put a cone on my saff when i first got my saff and it made it feel unresponsive to me.im an airbox fan myself.i have mine drilled at the lower section of the front and up the underneath where it sits on the inner wing,plus i have the centre light out of my quads for airflow.
plus if cones are so good why didnt the 500odd bhp touring cars run them?
and i much prefer the look in the engine bay of the box
  #48
Chip
Chip's Avatar
Tuning rumours for dummies?
  #49
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Phil,
APMSLOL at your comments. Obviously Euan's 30bhp gain when ditching his cone for an airbox was a figment of his imagination .
I measure underbonnet temps and in high ambients, you wouldn't believe what they climb to (on track) . Obviously a cone would be ideal for you, as the noise and the fact that you never work you cars hard would mean you wouldn't notice the loss of 30bhp .
  #50
Franco
Franco's Avatar
Thats right Rich............. But i'm just a shipping manager!
Old 29-03-2007, 01:03 PM
  #51
Stavros
DEYTUKURJERBS
Stavros's Avatar
Because ABOVE that is BAD, below that is acceptable enough to not need to go to big efforts like WI.
Remember, this info is coming from GrpA/WRC Escorts, and its a trade off between weight and power, if they injected water below 40degC theyd need a MASSIVE tank, so the decent comprimise was 40degC.
But 10deg is WAY better than 40deg in reality.
Unless you listen to the expert there
  #52
Chip
Chip's Avatar
Cossierich, the issue is that if the charge temps drop too low you can start getting issues with fuel dropping out (ie condensing)
But Phil is of course spouting shit about 40 degrees being the mythical perfect figure.
Old 29-03-2007, 01:04 PM
  #53
Bullett
Bullett's Avatar
exactly rich,the more dense the air the more fuel you can burn which in turn means more power.
Old 29-03-2007, 01:06 PM
  #54
CossieRich
CossieRich's Avatar
Chip,
how low do you have to go before fuel starts condensing or are we talking the north pole sort of temps well into minus figures lol
  #55
Rick
Rick's Avatar
childish question - does chatter totally dissapear when you run an airbox?
Old 29-03-2007, 01:07 PM
  #56
COSSIE CAL
COSSIE CAL's Avatar
soall round its best to run a standard box?
Old 29-03-2007, 01:09 PM
  #57
Stavros
DEYTUKURJERBS
Stavros's Avatar
The "too low" temps are proper north pole spec, actually they are impossible on a turbo car really considering the heat a turbo puts into the inlet charge.
No, tho it does a good job of muffling it.
Old 29-03-2007, 01:10 PM
  #58
Franco
Franco's Avatar
Oh Rainbirds going to love answering that one!
Old 29-03-2007, 01:13 PM
  #59
Bullett
Bullett's Avatar
nope,especially with the recirculating cuntvalve out.
Old 29-03-2007, 01:14 PM
  #60
Chip
Chip's Avatar
Chip,
It varies depending on the AFR you are running and the design of the inlet.
And also if you are looking for optiumum for economy or optimum for performance.
40 degrees or more is a good place to be from an economy point of view in most instances, but I cant imagine any car will make max power at that temp.
Its a very very complicated subject, as the heat of the charge effects the burn rate, which in turn effects how advanced it can be iginition wise before seeing det, which then effects where you can position the PCP in the cycle etc, seriously you could write a PHD on a small part of the subject of intake temps!
(and I couldnt, hence im not going to try and name numbers, lol)
But 40 on a YB is definately a load of shite for optimum power, its way lower than that im positive, so ive no idea why Phil is quoting it, unless for some dum reason he really believes that!
Compression ratio also effects the amount of heat you want to see or not, so if you combine that into the equation Phil can probably come up with something so innacurate it risks putting the planet out of orbit as a result of the enormous wave of stupidity rippling out from everyone's screens
Old 29-03-2007, 01:25 PM
  #61
Micky The Finn
Former Sponsor
Micky The Finn's Avatar
nope,you want to here mine when being used to its potential,sounds strange but even with a peltor on you can here it chipring away to itself.
Old 29-03-2007, 01:26 PM
  #62
Deleted by Request
Former Sponsor
As said its not from ME..but from a proper pro I bet it really irritates the book worms i am blessed with such knowledge...40c is where its at for optimum power on a YB.
Whats your view on this Mike as you know the person who told me
Old 29-03-2007, 01:30 PM
  #63
Chip
Chip's Avatar
Yes Phil, thats right, 40 degrees no matter what turbo is fitted, no matter what boost its running, irrelevant of cmpression ratio and nothing to do with what AFR its running.
They ALL work best at 40
You didnt misunderstand anyone at all, physics really is that simple
Old 29-03-2007, 01:32 PM
  #64
Deleted by Request
Former Sponsor
What on Earth are you banging on about Chip?...if you can get 40c air charge temps no matter what spec you will have the optimum burn...so please stay off the books.
Old 29-03-2007, 01:34 PM
  #65
Chip
Chip's Avatar
Phil, you really do believe that you have understood that correctly dont you?
Old 29-03-2007, 01:41 PM
  #66
Deleted by Request
Former Sponsor
...who cares...its still 40c.....its also the best temperature to wash your clothes at
Mike your very quiet?
Old 29-03-2007, 01:43 PM
  #67
Chip
Chip's Avatar
Even that varies phil, depends if they are colour fast or white etc
Old 29-03-2007, 01:47 PM
  #68
lead_foot
is awesome
lead_foot's Avatar
Who??
Old 29-03-2007, 01:50 PM
  #69
Franco
Franco's Avatar
Who??
Harvey by what Phil's suggesting........
Old 29-03-2007, 01:51 PM
  #70
Chip
Chip's Avatar
Who??
That bloke that said something that Phil misunderstood
Old 29-03-2007, 01:53 PM
  #71
pete mcrash
saff is working!!!...atm
pete mcrash's Avatar
how many "pro's" have u been with.....................
Old 29-03-2007, 01:55 PM
  #72
Deleted by Request
Former Sponsor
...not harvey no.....
...sorry if it dissapoints people but its actually a fact...40 is the magic number...life also alledgely starts then too
  #73
Rippers
Monte Geek
Rippers's Avatar
Best Airbox I've seen was the works one I got from Tim Finch
Which was a carbon lid with 70mm outlet on a modifed Sierra sized base
Hows that for air flow
But was no good to me as I had standard headlights so I modified another sierra base to take the original Esc Cos feeder pipe drawing from behind the foglight grill
My question is what benefit would I have to having a hole cut in the box behind the standard headlight? I can't see how it would get any airflow? I can understand the morrette users with the ducts
Old 29-03-2007, 02:00 PM
  #74
foreigneRS
Testing the future
foreigneRS's Avatar
i bet it's ahmed - the god of all things yb
Old 29-03-2007, 02:04 PM
  #75
Franco
Franco's Avatar
Edit - I'm a cunt!
Old 29-03-2007, 02:16 PM
  #76
Rippers
Monte Geek
Rippers's Avatar
Mate you never read.. you must just look at the pictures
Old 29-03-2007, 02:18 PM
  #77
Franco
Franco's Avatar
No i have to work as well as read!!
So yes i just look at pictures!!
  #78
Chip
Chip's Avatar
Undoubtably amhed is a wealth of valuable info.
Also undisputed though is that Phil trying to repeat him ISNT
Old 29-03-2007, 02:33 PM
  #79
Garage19
Garage19's Avatar
Ha
We should write that!
Old 29-03-2007, 02:36 PM
  #80
dovboy
dovboy's Avatar
if its 40 deg,why bother with nos
Quick Reply: FAO mr rainbird,rapidcossie or other people with std airbox
