Headlamp problems!
Old Sep 13, 2004 | 11:14 PM
James's Avatar
James
Default Headlamp problems!
I've got weird problems with the headlights on the sierra, i have side, dim dipped beam with igniton on and in sidelight position [dim-dip] then when i go to dipped beam [second position on switch] i only get it on the passenger side, i've checked the bulb and it's not that & tried a new one just incase, gone through all the headlight/dim-dip relays and swapped them with others, although whether the other ones is any good or not i don't know.
Now i have a feeling someone experienced the same and found it was the switch???
Old Sep 13, 2004 | 11:30 PM
James's Avatar
James
Problem sorted!
Traced the wiring diagram and it's wired through the rear fog relay, which obviously i didn't check, gave this a wiggle and we're up & running!
Old Nov 14, 2004 | 11:14 AM
Iain's Avatar
Iain
James,
Where is the rear fog relay? I seem to have the same problem but I can't see a rear fog relay on any of the diagrams I have....
CheeRS,
Iain
Old Nov 14, 2004 | 06:20 PM
James's Avatar
James
Relay B in the main fuse box under the bonnet.
Old Nov 14, 2004 | 06:38 PM
Iain's Avatar
Iain
Thanks James,
On my car (3 door) the relays are numbered rather than lettered, the second one, II, is described in the owner's manual as front fog lights. I assume we talking about the same thing; I swapped all the yellow relays round to see if they made a difference but no joy
Identical symptoms though, looks like I'm going to have to do some hard work with the multimeter myself, thanks anyway
CheeRS,
Iain
Old Nov 15, 2004 | 09:23 PM
James's Avatar
James
Ah, no sorry, mines a later one on a K plate.. I have both, letters and numbered relays!
Old Dec 5, 2004 | 10:19 PM
Iain's Avatar
Iain
Can anyone tell me where the bulb failure module is located on a Sierra? I'm still having problems with my dipped beam, the voltages are all over the place andI annot make any sense of it . I'm also seeing an intermittant phantom error for the rear lights and suspect (hope) the bulb failure module is to blame or all this...
CheeRS,
Iain
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
