AFR gauges
#44
Sponsor
and im still useing a bosch sensor in the same area fitting exactly the same as all the lc1s mike and im still on the original sensor wihch came with the zietx and guess what sensor it is ..... yes u guessed it a bosch one same as the innovate
alot of the faults come down to the controlers packing up or giving incorrect voltages
#46
*** Sierra RS Custard ***
Originally Posted by JayCos
and im still useing a vosch sensor in the same area fitting exactly the same as all the lc1s mike and im still on the original sensor
Mike was a little wrong about the temperatures though it would appear.
The sensor can hack 1300 degree gas temps and 900 degree sensor temp
Still worth having the extender anyway though just to be sure, so let me know if you do have one in stock Mike as I still want it.
Mine gave error 04 IIRC, "sensor open" I think it may have been
#48
nice and ull find that you will fit a new sensor and it still will read error 4 i bet my left bollock the controler has gone , chip i told you before to buy a ziextronic
Only seen an hour or two's use so far though, so really poor show if it is fucked already!
#50
Sponsor
#51
Bloody hell, thats not even 500 degrees sensor temp then!
And only 700 degrees of gas temp, in which case Im sure I have exceeded that fairly often!
Ah, didnt realise it was sold, you likely to have any more in stock in the next few weeks? (wont be using it again till well after the ring trip anyway so no massive rush)
#59
I will be fitting my Innovate one after work tommorrow so will get some pics up and lets folks see it.
All ready had good reports of Doug etc
I got the heat sink today and the rest is on its way.
the heat sink actually moves the sensor out of the downpipe a bit to help protect it from the heat.
#60
i have the innovate one and have mounted it here
it says on the add that you can data log does anyone know if you can do this with the xd-16 and the lc-1 i havent really looked in to it too much yet
as i have just found that i need to do a head gasket i love cosworths
#62
cheers fatboyz...did you remove the whole car display and replace it with black plastic?
#63
FAO the guys with the inovate LC1s
where did you get your switced live from and where did you ground it?
do you need to conect the calibration wire too?
#64
Got my LC-1 and XD-16 from Mike today
fitted it after work with a bit of help from Simon(sas)
Wish an auto electrician could see my wiring...i would get shot
here is some pics of it temporarily fitted
Mike ignore the misses call, it was one of these "Im a gas fitter not a electrician mistakes"
#69
16 is a little lean and 11s at the start of boost is to rich imo .Euan have you calibrated it correctly ?
Been out in the car tonight again and the figs are wee bit different from what i thought.
still not got definate figs as the thing is too quick to concentrate on the gauges
#70
Originally Posted by Stu @ M Developments
High 11s around peak torque is fine IMO Jay.
#71
PassionFords Creator
#73
I am going to get one next week, I like the idea of the warnings and data loging.
#75
i used an LC-1 / XD-1 setup and was very impressed with it.
my 1st LC-1 failed tho, and i got it replaced under warranty.
the analog outputs are VERY sensitive, DO NOT let them anywhere near an earth, you'll blow the DAC
#77
you can datalog direct from the LC1 aswell as the ECU
i used top do it on the ECU as it had more data to work with (i had Emerald ECU)
#78
I've just bought an LM1 package - should receive it tomorrow intime to do a bit of testing enroute to the Nurburgring....
....question being what are considered as 'safe' values & the brink of 'dangerous' values at the following times...
i) cruising off boost
ii) coming onto boost
iii) full hammer, full boost
Thanks all!!!
Thanks all!!!
#79
Lee..i know my car doesnt melt at the settings its at just now so i just look for a change.
dont think you want to hold more than 11.5 high up the revs on full boost.
#80
This was Stu's car (MSD). please note that the figures in the red highlighted area are dangerously
lean readings due to an old fuel pump that was in poor condition.
