Compression Test
Old Mar 25, 2007 | 09:46 PM
AndyP's Avatar
AndyP
Default Compression Test
Is it a big job? What's involved?
Old Mar 25, 2007 | 09:48 PM
GARETH T's Avatar
GARETH T
warm the engine,,, pull the plugs out,, screw the tester into plug hole, make sure the engine wont fire (pull king lead or whatever) full throttle and crank the beast over and not reading on gauge
do each cylinder,,, than you can put a little oil in the bores and do it again
Old Mar 25, 2007 | 09:50 PM
AndyP's Avatar
AndyP
GARETH T Cheers mate, much appreciated
GARETH T's Avatar
GARETH T
no problemo
Old Mar 25, 2007 | 09:53 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Oh - and keep your foot to the floor on the accelerator and count it cranking for 6 cycles
GARETH T's Avatar
GARETH T
i said full throttle
Old Mar 25, 2007 | 09:56 PM
Big Will_'s Avatar
Big Will_
And i'm on very strong pain killers after a bandsaw decided i could manage with 9 fingers and had a go at removing one last night
Old Mar 25, 2007 | 09:57 PM
GARETH T's Avatar
GARETH T
better start learning that 9 times table now then
phil_focus's Avatar
phil_focus
how much is a "little oil" ???
t-spoon or half a pint?
Old Mar 25, 2007 | 09:58 PM
GARETH T's Avatar
GARETH T
a tea spoon
Old Mar 25, 2007 | 09:59 PM
Physio's Avatar
Physio
Dont forget to keep the throttle pressed to the floor
HTH
Old Mar 25, 2007 | 10:00 PM
GARETH T's Avatar
GARETH T
ah thanks aj,, we forgot about that
Old Mar 25, 2007 | 10:03 PM
Physio's Avatar
Physio
Im always happy to help Gareth
Big Will_'s Avatar
Big Will_
Nob off
It's still firmly attached thank you very much - even if it is predominantly by the stitches my local A&E department lovingly installed `
P.S - Teaspoon of oil is plenty
phil_focus's Avatar
phil_focus
Old Mar 25, 2007 | 11:29 PM
Benni's Avatar
Benni
Ban[B][/B]ned
HTH
PMSL! You ever thought about running your own tuning company?
TPM961
Jan 15, 2018 10:50 AM
Prickly_buzz
Dec 7, 2017 09:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
