converting vhs to dvd
The easiest way, as said, is to use a DVD recorder - simply plug the VCR into the DVD-R with a scart cable and press play on the VCR, and record on the DVD-R - simple!
If you WANT to do it on a PC, you need a good quality/spec PC (as it will be writing the DVD content on the fly) with a video capture card - these usually have a composite (yellow, video, RCA input - some have s-video input aswell) and some recording software.
You need to plug the VCR into the PC via the capture card using a breal-out lead (scart on one end, which terminates in 3x RCA's : yellow for video, and red + white for audio) - then the audio RCA's from the VCR need an adapter to convert them to a single stereo 3.5mm jack to plug into the audio line in on your soundcard....
Then you need to play the video, and use whatever software you have to "see" the video (and audio) and encode it to DVD - it's gonna be a resource whore tho, so don't expect to be able to do anything else while you do it
Or, if you have USB 2.0 on your PC (most do these days), you can try this;
http://cgi.ebay.co.uk/Video-Capture-...QQcmdZViewItem
You still need a break-out lead for your VCR tho;
http://cgi.ebay.co.uk/SCART-TO-3-RCA...QQcmdZViewItem
Tho, tbh, I wouldn't expect the quality to be super hot - you;d still be better off using a DVD-Recorder hooked up to the VCR I reckon.....
Carl - yes, the DVD will only be VHS quality - but anything recorded from a VHS cassette will only be VHS quality - regardless if recorded onto a PC and then burned to DVD, or recorded directly to a DVD using a DVD Recorder...
And there is no "proper" or "improper" way of doing it - you just do it the way that is best for you Or the way it is easiest - which will be using a DVD-Recorder hooked up to your VCR using a scart lead
look at one of these probably the cheapest option,
http://www.bigpockets.co.uk/cat.php?...41b84bfa62684c
Most commercial VHS tapes have copy protection on them (Macrovision or similar), so simple scart leads may not work (they didn't for me!)
But I have heard of something called a Smart Scart lead with some electronics in it that overcomes this though I believe this may be illegal unless you are using it for its main purpose in life.
That useful, what software do you need will media player work ok?? would that usb dongle be ok for playing camcorder stuff back (thats not digital) and putting onto hard drive or dvd?
It was a while ago but as I recall I didn't use any software, just set the tape playing and pressed Recorded on the DVD with input via the Scart input.
But I wasn't doing anything about editing or compressing which would be beyond me anyway!
I have had problems recording DVD's to VHS tho, as DVD's use copy protection, and you cannot do the copy with a scart - have to use composite video cables with seperate audio, and even then the recording is dodgy. This is due to Macrovision, but NEVER heard of a VHS tape that has it
Maybe I was unlucky but I promise the tapes I was backing up had macrovosion because the DVD recorder announced that it was there.
The on-screen message was the only reason I was able to Google for a solution - without it, I wouldn't have known what to look for!
ive been transfering a load of old bmx vids to dvd lately and this is how ive been doing it
first you will need to buy the following
http://cgi.ebay.co.uk/VIDEO-CAPTURE-...kparms=65%3A12|66%3A2|39%3A1|72%3A1690|240%3A1318|301%3A0|293%3A 1|294%3A50
dont bother using the software supplied to transfer the video, all will be explained further down in the post
then you will need a male to male rca audio/video lead
http://cgi.ebay.co.uk/2M-3-RCA-PHONO...kparms=65%3A12|66%3A2|39%3A1|72%3A1683|240%3A1318|301%3A1|293%3A 1|294%3A50
and if your video player dose'nt have audio/video rca outputs or a s video connection then u need to buy one of these
http://cgi.ebay.co.uk/SCART-to-3-X-R...kparms=65%3A12|66%3A2|39%3A1|72%3A1683|240%3A1318|301%3A1|293%3A 1|294%3A50
once you have connected the video player to your pc or laptop download vlc player
http://download.cnet.com/VLC-Media-P...-10267151.html
this is a media player that can play pretty much any file and can record your captured videos
once you have done this open vlc player and follow the guide in the link
http://www.scribd.com/doc/25400/Vide...rding-With-VLC
change the vlc settings to the same as the ones in the link
it dosent show it clicked in the link but click on the play locally box, this enables you to see the video playing whilst you capture it
when you are naming your video remember to put the encapsulation method afte the title, so for example zero tolerance.mpeg.ts
click ok and that window will close
you are now left with the direct show box, click ok and press play on your video player and the video should start playing and be captured by vlc, to stop the capture when your done just press the stop button on vlc
now your captured video will be saved in the vlc folder, click on file then on quick open file and your video should be there
now to burn to disc, i personally use dvd flick which is a free program which allows you to edit, add titles etc
http://www.dvdflick.net/
and a guide to the settings
http://www.dvdflick.net/guide/index_en.html
the quality should be quite good but it depends on the condition of the video your are transffering to start with
2Evos & 1 Escort Van :-)
VHS to DVD Transfer is currently the most professional VHS to DVD Transfer which is specially designed to transfer VHS videos to DVD with super fast speed and up-scale output image and sound quality! It supports to transfer videos from DV, VHS Cams, Web Camera to hard drive, create home DVDs and encode the transferred videos directly to AVI or MPEG-2 format. Meanwhile, if you want to transfer the VHS videos to other popular formats, the AVS Video Recorder will directly connect you to the video converter to help you fulfil the task, try!
I went down to my local Photo shop and got a few done for about £40 it was easy and no stress at all. They were nicely labelled and cased as well. I would do that unless you want to start messing around with cables etc.
