cosworth diffs
cosworth diffs
do they get noisy cos they are knackered, or do they ofetn leak out all their oil
reason i ask, is my rear diff (i think) is starting to get noisier. it sort of whines when you let off the throttle, but if you re-apply it, or dip the clutch the noise goes away.
is this likely to be the bearings, teeth, or diff oil?
i have bought me a new runaround so can now get round to doing these jobs i didnt do before.
also, if i need a new diff, how can i tell if i am buying a good one or not
car is a stage 3 saff 4x4
Testing the future
sounds more like gearbox input bearing to me if it stops when you dip the clutch.
can you hear a difference at standstill between clutch up and down?
if it is diff, will need a rebuild. worth having the VC uprated while you're there. think marco can get them done
JJ
its definately coming from the back so pretty sure its the diff
just been getting noisier over the last 2 months or so
so just get it overhauld, or stick a new (S/H) one on?
any ideas on price?
any ideas on price?
Testing the future
Originally Posted by JjCoDeX75
Out of curiosity - how much work to fo the input bearing on the gearbox? mine coudl do with doing methinks
JJ
JJ
am i right?
am i right?
JJ
Testing the future
no - if you put the clutch pedal down, you stop turning the gearbox input shaft. if that is not turning, the bearing cannot make a noise
clutch release bearing is other way around - doing nothing without pedal down, doing something and being loud if knackered with pedal down
diff will either make a noise under acceleration or deceleration - deceleration still takes place with foot on clutch (wind resistance, rolling resistance etc) - although not as much as with engine braking
Resident Wrestling Legend
JJ
take to gearbox bloke with 15 inch deep socket
split gearbox casing
chaning bearing
put back together
adjust the adjuster to set the preload on the countershaft
job done
to be honest mate, it's much easier to give the box to them and get it overhalled fully, you are only talking about an extra hour or so to get the rest of the box to bits and the bits changed
gingeRS
does it only do it in first gear ..when you let the clutch go ..
mines the same ..if it is...
i got two low mile diffs from taz on here ...
when he was breaking his 4*4
but still waiting to get them on the car
the whine does piss me off ..it sounds so shonky when you pull off in first gear ..
Re: cosworth diffs
hi bud
as mike said to be honest once they start whining they are on the last legs front bearing has worn out and is ready to collapse you might aswell have full overhaul
come on guys these diff are old as fook and lets be honest how many of you service your diffs ,i bet i could count them on one hand
most only have them serviced once they pop when they need it
we rebuild any gearbox aswell all dyno'ed to make sure it's ok
we uprate any vc not just fords they can be any as long as it has a vc
Originally Posted by avid-fan
marco polo
how much is it to service my old diffs then please .. 4*4
when they eventually get replaced
it depends on what you want can do normal rebuild if you want or you can have uprated planet gears with uprated vc to 120Nm (for better handling/traction) on the normal vc plates or you can have the nickel coated plates which increase the 7"vc to 180nm ...... it wont need replacing once you have it all done
marco polo
cheers for the info..
once there out the car ..they will pass your way
03-11-2015 04:08 PM
