can someone put to rest these marking on actuators!
General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
so if i ran no amal valve with a actuator thats marked 16psi then it will open up a 16psi? so that would be its max without a amal valve or bleed valve?
Yep, if it's in fine fettle. I wouldn't put it on unless yours is chipped though, and even then I'd prefer a proper Garrett -31 and correctly jetted amal valve. Personally, I prefer the ECU to have some control over the boost levels.
