Actuator help....please
Old Mar 17, 2007 | 08:44 PM
lawnsy's Avatar
lawnsy
Default Actuator help....please
the past week i have slowly been losing boost till the point 2night it was struggleing to peak 20psi when it normaly peaks at 32 so i bypassed the amal valve and plubed the turbo straight to the actuator and tryed it down the road and it would not boost passed 8-9 psi so me is thinking the actuator is fucked......
so
it has a FORGE actuator on it and it looks like it comes apart the same as a dumpvalve so can i buy a overhaul kit for it or has anyone near durham got a -34 i can buy........
NEED MORE BOOST AGAIN....... ....it feels slow
Old Mar 17, 2007 | 08:50 PM
abdr500's Avatar
abdr500
most likely a leak some were else
Old Mar 17, 2007 | 08:58 PM
BigErn's Avatar
BigErn
I got a Forge one you can try on it mate to make sure it is the actuator before buying a new one
Old Mar 17, 2007 | 09:06 PM
lawnsy's Avatar
lawnsy
cheers mate....you doing anything about dinertime tomorra???
Old Mar 17, 2007 | 09:07 PM
Billabong's Avatar
Billabong
If the actuator is set for 9psi, then that's all you'll see by removing the amal valve from the equation - the amal valve bleeds off to give the increased boost levels. They are serviceable though:
http://www.forgemotorsport.co.uk/con...t&catalog=0019
If the spring has weakened, it could be being overcome by boost pressure at higher levels. Could be something amiss elsewhere like abdr500 says, do you have a dump valve fitted as that could be leaking. Any strange noises?
Old Mar 17, 2007 | 09:08 PM
BigErn's Avatar
BigErn
Giz a text mate, should be free for a bit. Ive sent you my number by PM.
Old Mar 17, 2007 | 09:13 PM
lawnsy's Avatar
lawnsy
checked all pipes today all tight and no splits and tryed blocking dumpvalve off but still the same....but the actuator has been funny for a bit i have had to keep adusting it up to get me boost back to 32 but now the preload is right up i have to pull it easy a hole and a half to hook onto wastegate and it struggles to hold 8-9 psi without amalvalve
Old Mar 18, 2007 | 08:12 AM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
....me
Old Mar 18, 2007 | 08:20 AM
Roosie's Avatar
Roosie
500bhp Cosworth in making
whats difference between -31 and -34 ??
Old Mar 18, 2007 | 08:30 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Could the Penny Washer now be bent on the turbo ?
Steve.
Old Mar 18, 2007 | 08:32 AM
pete mcrash
....about Ł10........
Old Mar 18, 2007 | 10:02 AM
lawnsy's Avatar
lawnsy
-34 got stronger spring than -31 for more boost
Old Mar 18, 2007 | 10:03 AM
lawnsy's Avatar
lawnsy
....me
much ya want for it??????
Old Mar 18, 2007 | 10:10 AM
pete mcrash
...no it dosn't.....it has a greater lift off pressure
Old Mar 18, 2007 | 10:11 AM
pete mcrash
....me
....Ł30 fella...
Old Mar 18, 2007 | 10:14 AM
lawnsy's Avatar
lawnsy
mmmmmmm so how much ya want for it?????
i popping to sunderland in a bit to try bigern's on my car just to make sure it is that and if it is i either need a new spring for mine or a CHEAP actuator
Old Mar 18, 2007 | 10:47 AM
pete mcrash
look ^^^^^^^^^...... ....its to fit a 4x4 t34....will it fit
Old Mar 18, 2007 | 03:59 PM
lawnsy's Avatar
lawnsy
well tryed new actuator on today and got boost back
and now the turbo is smoking even worse...
Old Mar 18, 2007 | 04:32 PM
Billabong's Avatar
Billabong
Old Mar 18, 2007 | 07:58 PM
lawnsy's Avatar
lawnsy
i want to send it away for a rebuild but i want to goto the passoin ford meet and know it will be not back in time......
Old Mar 19, 2007 | 03:02 PM
pete mcrash
i had my last turbo rebuilt it only took a week....2 days of that were the post....plenty people off here that will do it for u
Old Mar 20, 2007 | 10:57 PM
BigErn's Avatar
BigErn
Give Andy Urwin in Newcastle a bell mate, apparently he used to work for Turbo Technics I think and is supposedly more than capable with rebuilding a turbo.
0191 267 0999
Old Mar 21, 2007 | 07:56 AM
lawnsy's Avatar
lawnsy
dropping it off at turbo active this week mate....
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
