bloody printers
bloody printers
any one know any thing about them .
I have a brother printer ,scanner, fax ,copier all in one thing .
The yellow cartridge ran out,so i think no problem and buy a new one .Instal the cartridge and away we go ,but no the bloody machine keeps telling me the cartridge is not instaled ,i even got a second cartridge incase the first was dud
Any one had a similar experiance or have a clue what to do
I get that all the time with my HP all in one.
Install cartridge, themn immediately turn off machine when cover is closed back up and leave for a few minutes, works with mine anyway worth a go ?
I got my Hp PSC 950 as it does COLOUR FAXES, trouble is no one I know has a colour fax!!
Originally Posted by NUTS RuS
Did you pull the plastic tab off ?
will try the turning off thing,see if that works
did you actually tellt he printer you installed a new cartridge? should be in the cartridge setup/alinement settings, usually it'll pop up when you turn the printer on after putting a new cartridge in but some are different.
You could always read the manual to see what that says
Is it a proper cartridge or a compatible? i've had problems with the compatible chipped cartridges before for these all in one teas-made/breadmaker printer things. If you put the old cartridge back in does it see it???
Sierrasideways
15
31-08-2015 10:10 AM
