ACT sensor help needed
Old Mar 14, 2007 | 01:15 AM
david's Avatar
david
Default ACT sensor help needed
Right i need to either find a very small act sensor ie about a 6-8mm thread size that will operate at 29ohms , 12v.
or
can I run an XR3i 8v EFI ecu without the sensor plugged in without it fucking everything up ?
Reason im asking is that im doing a very basic, budget zetec on bike t/b's and running with the 3i ecu etc for now and i dont have anywhere large enough to tap in the original ford sensor
This is the only problem ive got left to sort now, well apart from the engine mount, exhaust etc etc
Old Mar 14, 2007 | 02:40 PM
GARETH T's Avatar
GARETH T
just cable tie the standard sensor by the air intake
Old Mar 14, 2007 | 03:35 PM
scruffythefirst's Avatar
scruffythefirst
Yup, no need to have it inside the trumpet, just inside the air filter will be fine.
Old Mar 14, 2007 | 03:41 PM
david's Avatar
david
thought about doing that, seemed a bit of a bodge but if it solves the problem then why not.
Old Mar 14, 2007 | 04:27 PM
foreigneRS's Avatar
foreigneRS
Testing the future
build a plenum with a single throttle plate and put it in there
seriously, as suggested you could have it in the airstream somewhere. but where? will one particular intake be hotter than the others? they are not the most robust of things either and are normally downstream of a filter
Old Mar 14, 2007 | 04:37 PM
david's Avatar
david
Will tie it up and see how it gets on, can always be changed at a later date.
manuel boeckx
13
Oct 3, 2015 02:29 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
kosienutter
31
Aug 22, 2015 09:55 AM
muz
Aug 16, 2015 12:57 PM
col93saphcos
Aug 7, 2015 03:21 PM
