lower temp fan switch, where from?
Old 12-09-2004, 01:27 PM
Paul J
Paul J's Avatar
Default lower temp fan switch, where from?
My radiator fans come in too late (105c on laptop) would rather have them come in much sooner.
Do ford do lower one's (part no)?
What is the best temp to keep the engine at?
cheers, Paul.
Old 12-09-2004, 01:29 PM
vroooom ptssssh
It Wasnt Me!
vroooom ptssssh's Avatar
i got an XR2 fan switch (brown) and it came in at a quarter on the guage on my S1
Old 12-09-2004, 02:19 PM
Paul J
Paul J's Avatar
Hmm sound's better, at the minute on the gauge its touching red when they cut in, but they seem to cool ok once running.
Demon tweeks sel an adjustable sensor but gotta cut hose to fit it and its bout £50, rip-off cunts.
Old 12-09-2004, 02:58 PM
bbigman2000
bbigman2000's Avatar
be interested if you find one mate, otherwise you could wire a simple switch into your dash and switch it on manually when needed, I have same feeling about mine I dont like the time it takes to cut in.
Old 12-09-2004, 03:00 PM
vroooom ptssssh
It Wasnt Me!
that sa bit late!!! i got mine from a local motor factors. maybe ure is pretty much on its way out, usually people fit cossie ones to RST's.....
Old 12-09-2004, 03:11 PM
bbigman2000
true it looks late on the gauge mate, but how accurate is the gauge thats the question.
Might try a new sensor in mine just for peace of mind
Sexy-RS
Sexy-RS's Avatar
Yeah but its not good switching the fans on if the thermostate hasn't opened surely?
Old 12-09-2004, 03:13 PM
gus
gus's Avatar
its a ford gauge! so pretty accurate i would say
Old 12-09-2004, 03:20 PM
bbigman2000
true that, but it would only be for use long after the therm has opened, it is probably just as damaging to run a engine to cold as it is to run it to hot, so one would be advised to know fully what there doing and what the water temp should and should not be
Old 12-09-2004, 03:21 PM
bbigman2000
just say it
Nice mota bro
Old 12-09-2004, 03:34 PM
vroooom ptssssh
It Wasnt Me!
let the car idle till and feel the top rad hose for when the thermostat opens, then go to the temp guage, and note where it is, and wire up a fanny switch and everytime it get s to jus after the point u noted, switch the fans on
Old 12-09-2004, 04:43 PM
Paul J
Paul J's Avatar
Not fitting a manual switch cos ill forget but i could put a manual over-ride in, but thats just hassle and not worth it if i can get a lower switching sensor.
Thought they had temp stamped onto them but mine is blank.
Ford gauge is crap but i also have a ecu monitor which gives me temp in celcius(sp?)
Old 12-09-2004, 05:29 PM
ballin
ballin's Avatar
just wire it so you can turn it on manually.
it will still come on automatically if you forget anyway
Old 12-09-2004, 05:49 PM
Paul J
Paul J's Avatar
Old 12-09-2004, 05:59 PM
phil4x4saph
phil4x4saph's Avatar
Go to a DECENT motor factor and they can look up the cut in/out temp for all the fan switches available.
Almost all switches are the same thread although you may need to change the terminals to suit the new switch (hardly brain surgery is it?!).
PM me if you cant get any joy and I'll sort you out a part no. or stick one in the post.
Old 12-09-2004, 06:07 PM
Paul J
Paul J's Avatar
phil4x4saph, ill have a looksy tommorow if not ill bung you a PM
Old 12-09-2004, 06:34 PM
ballin
ballin's Avatar
yeah fair enuf mate did see your post but its really simple and the best option imo
Old 13-09-2004, 10:38 AM
Uncle Henry
Uncle Henry's Avatar
Burton power or whatever they're called sell them - theyre listed in their catalogue with the temps. also different thermostats as well.
hth
Old 13-09-2004, 10:43 AM
Jim Galbally
Jim Galbally's Avatar
cossie ones are high 80degrees i THINK that'll do the trick... abuot 12quid from ford new
Old 13-09-2004, 10:20 PM
Paul J
Paul J's Avatar
Uncle Henry, So they do, looked through but must of missed it fts801.88 looks ideal, 88c swith
Looks like the 4wd YB one, so your spot on there Jim.
Thanks all, Paul.
Old 13-09-2004, 10:41 PM
AndyRST
AndyRST's Avatar
The Cossie 4x4 fan switch cuts in at 88ºc and cuts out at 82ºc i believe
Old 13-09-2004, 10:47 PM
McPikie
McPikie's Avatar
Link that to a 78 or 82 thermo from burton, laffin all the way to the bank
Old 13-09-2004, 11:05 PM
Paul J
Paul J's Avatar
Only do a stat in 92ºC form for my engine, Zetec turbo, is that gonna be a problem?
Old 13-09-2004, 11:10 PM
AndyRST
AndyRST's Avatar
are you sure you cant get a lower stat than 92ºc ?? That seems a bit high?
Old 13-09-2004, 11:11 PM
Paul J
Paul J's Avatar
it is generally agreed that for optimum power and torque, an engine requires a working temperature of around 70oC/158F. this is not optimum temperature for economy......
Lower the better then, wonder if a cvh stat will fit (different part numbers )?
Old 13-09-2004, 11:12 PM
Paul J
Paul J's Avatar
AndyRST, thats all Burton list
Old 13-09-2004, 11:15 PM
AndyRST
AndyRST's Avatar
Might be worth seeing if a CVH stat will fit? I have a 82ºc stat, so if it fits you could alsways use a lower temp one
Old 13-09-2004, 11:24 PM
Paul J
Paul J's Avatar
Should have a cvh one floating round, ill give it a try.
Old 14-09-2004, 06:40 AM
alan rainbow
alan rainbow's Avatar
use a escort cosworth first stage fan switch
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
Mark RS
12-10-2015 06:01 AM
Fudgey
21
30-09-2015 06:19 PM
cossie330
27-09-2015 04:13 PM
Quick Reply: lower temp fan switch, where from?
