rs/3i fuel pump relay
Care Free.......
anyone know where i can get one? tried halfrauds, local ford place
scrapyards etc etc... but they cant supply one.. gettin pretty desperate now as i use the car everyday so any help would be mint.
cheers..
cheers..
It Wasnt Me!
if your needing a temporary solution to use the car, bridge these:
![](https://img.photobucket.com/albums/0803/vroooom_ptssssh/DSC00747.jpg)
Ive got an S2 relay wired into my S1 as you may know its even harder to get an S1 relay, but it should be the same.
oh, this basically bridges the 12v live to the fuel pump so it runs constantly when you turn ignition to #2, please be aware that it wont cut the fuel pump in an accident touch wood!!
Do ford not do them anymore?
I managed to get one but about two years ago for £27 I think.
I tried 2 in mine and they both get quite hot if thats normal?
Care Free.......
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
vroooom ptssssh ive told you a few times now you're not really meant to do that.
The ignition supply isn't designed to feed a pump that consumes 10A+ of current, additional to the fact the ignition circuits AREN'T fused
Someone is going to have meltdown one day from doing that.........
If you are after a relay i have a few second hand ones which work, im not using this as a sales pitch in any way, if you need one give me a shout
It Wasnt Me!
SafeChav, You've never told me i'd have a "melt down" U jus sid it's not very safe in the event of an accident iirc as fuel pump would still run!
And fuck asking him for a Relay ive asked numerous times and he's not gave me a price or f'all
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
And fuck asking him for a Relay ive asked numerous times and he's not gave me a price or f'all![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
If you run it off the ignition supply its also unfused, and not up to the job.
Either way...........its not ideal.
You've got no excuse really a proper S1 relay is only £25, which i've also told you numerous is times is far superior to the purple piece of shit S2's and XR3i's have.
You can't just plug it in, the pin pattern on the plug is the same, but the wires need changing around to different positions.
The reason your plug has been changed, i can almost guarantee is a result of having a wanky purple one plugged in to start with, they overheat internally, melt all their solder joints and eventually the heat conducts through to the plug and melts that aswell
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
Originally Posted by TeamGiroUnit
yep my one has melted ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Ok, so if I get a hold of one, could you tell me which wires go where?
It Wasnt Me!
Spank you very much, Ive possibly got a guy with one...but not sure yet waiting on a return pm. Still got that ECU1 Radio here
Originally Posted by Shings The BULB
IF this relay is the one that has the fuse on top of it- its the same as (i think) a mk2 golf gti
Care Free.......
They appear on eBay very regularly..........
Originally Posted by Ginge !
is anyone gonna tell this bloke he needs a new fuel pump as thats whythe relay melted or not ?
just finding my feet
what you mean a 15 year old pump,,,, that when it wears draws more current making the relay melt,,,,, or a 15 year old relay that failed due to a bald soldering joint,,,,,, but lasted 100k miles before it failed,,,,,,
its the pump, it will work again but you will need another one in 2 years average
my fuel pump realy just went on my nova.
its actually quite common but mine was because it got water in it.
u can probably take the cover off the relay and see the insides.
the tracks on the pcb may show signs, and will probably smell of a nasty burning/singeing smell.
only a blaitent sign or water damage or something similar would mean it definately aint ur pump.
because with electricity its now how much current u throw at a component. its how much it will pull.
so if the pumps fucked it would of pulled more than the usual 10amps or so and ruined the relay.
i'd be taking the relay apart right now and see what sort of condition its in.
a brand new original wehrle relay for mine was only £9.95
we'll he'll need a new relay what ever as his one melted.
unless the relay was full of water i'd check the pump out though. as there is probably a reason the relay went.
but if what was said above about the relays being crap and often going is right then might not be worth forkig out on a new pump if they are expensive.
could always run a cable from the battery to the pump, fuse it and put an ammeter on it and see what the pump is pulling.
But in the majority of cases yes, the pump more than likely will be knackered.
Care Free.......
TeamGiroUnit, is the pump on the car loud when it primes?
28 quid for a relay from ford
The buizzing should be veru quiet and gentle on a healthy pump, the one on my cabriolet was loud as fook you could hear it down the other end of the road when it primed
you've got PM aswell
you've got PM aswell![Top](https://passionford.com/forum/images/smilies/smile011.gif)
JK12
33
26-04-2021 12:09 PM
155lee
24-10-2015 11:11 AM
