dos command for format
Old Sep 11, 2004 | 06:36 PM
markk's Avatar
markk
Default dos command for format
anyone , i cant remeber it again !!
its time to format the hdd AGAIN fookin sick of spyware freeware etc etc
so i need the dos command pls !!
Old Sep 11, 2004 | 06:40 PM
Derek Burleigh's Avatar
Derek Burleigh
Erm......run FDISK off a DOS boot floppy and format from there.
Think DOS command is just "FORMAT C:" (assuming C drive)
Old Sep 11, 2004 | 06:41 PM
Jim Galbally's Avatar
Jim Galbally
aye its just format
but its a program, not a built in command, so you need to get hold of a copy (filename=format.com)
easiest thing to do is just fdisk and remove the partition... when when you go into windows setup program it will partition and format it FOR YOU
Old Sep 11, 2004 | 06:48 PM
Derek Burleigh
Beat you to it Jimbo!!!
Are you still fucking about with that wank XR4x4???
Old Sep 11, 2004 | 06:49 PM
Jim Galbally
del, check the siggy... got me a saph with a 24v v6 now
Old Sep 11, 2004 | 06:52 PM
Derek Burleigh
Oh yeah, put a Grandad engine in the Sierra? That sould give it a bit more poke.
Have you got the TT conversion fitted?
Old Sep 11, 2004 | 06:54 PM
Jim Galbally
no its not being turboed...
it does have some "toys" fitted tho... lol
Old Sep 11, 2004 | 07:43 PM
soulweavers's Avatar
soulweavers
If you plan to install XP an easy option is run your installation cd as boot up the it will ask if you want to format / partition etc. Goto bios and change boot up sequence, cd - floopy - hard drive.
Old Sep 12, 2004 | 09:12 AM
Matt's Avatar
Matt
dos will only format it to fat32 which (if you have a hard drive over 2gb) is not the right way to do it
let the os install disk do it for you
Old Sep 12, 2004 | 09:29 AM
saphycozzie-adz's Avatar
saphycozzie-adz
if its 98, type in format c: /q
this will do the format quickly and not in 30 mins!
bobsworth
77
Mar 24, 2016 09:30 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
gingeRS
17
Oct 2, 2015 09:42 AM
rsguy
44
Sep 29, 2015 03:29 PM
