wheel hitting the shock!
found out what my horrible scrapey reversing problem was... the inner edge of the wheel esccos wheel) is scraping on the shock!!!
this cant be right surely?!
also i cant for the life of me work out what the clonking when turning is thought it was tyre ctching arch liner... but it aint
aaargh!
aaargh!
bigwig, thats how we found out the shock hitting problem...
cant work out the going forward rubbing, as you gotta be going quite quick for it to happen... lol
coilovers are arriving ASAP... but i dont think thatlll solve problem as the width of the shock will stay the same!
is the rear end the same as a cossie?cos i had those wheels (soon to be reunited ) on mine and had no probs with 215/40/16s on with avo coilovers. if not do you want the entire rear beam off me cossie? still got it lying around,got new discs for it too!dont want much,need rid.
so its not catching on the spring then mate, nor the spring holder- but further down- surley it should still be a bit smaller in diameter shouldn't it??
oh, and i saw your old shed drving towards bromley about 20 mins ago- lock the doors, and pretend your out if he's heading your way
rear setup is same as cossie... ie seperate coil n spring (its the estage that have it all in 1)
also its rubbing on the thin part of the shock, below the spring/spring cup!!!
and thinking about it, the distance between the shock and the wheel can surely NEvER change? so why does mine touch only on full lock? WTF can be bust?
on the front? inner arch plastic liner! is it the same side as the washer bottle? if so the bottle may be hanging off(bolt not done up) and pushing the arch liner onto the wheel,had this problem for a bit on mine.soz thought your first prob was on back.
pretty sure its not catching
one side it rubbing slightly, but this is more of a smooth rub, not a knock knock knock like its catching on something
lennie's gonna have a look at it later for me
ppolybushes are being ordered asap just incase its that...
so i'll be replacing shox and bushes...
so unless ive got a fooked hub or a fooked wheelbearing i should be ok nothing else there to go wrong i dont think... lol
Jim IIRC you have standard sierra hubs up front and not cossie ones, so its very likely that you have less offset hence the wheel is closer to the strut
The clonking, does it only do it on full lock and is it from the front or rear
If front check tca's, tre's front wheel bearings
If rear check cv's, wheel bearings
front...
outer tca bushes are a bit manky if thats a help...
does it on any turning tbh but more noticeable on lock
on my frst had the same fault turned out that when i had got the wheel ballanced they used bang on lead wieghts and thats what caused the problem
also we had a bm in work on friday who hit a kerb and flat spoted his eim on the inner edge and that was hitting the suspension track rob ends
just ideas that i have all the best mate
Originally Posted by Jim Galbally
front...
plan of action:
on wednesday the following will be replaced: Outer TCA bushes (poly), suspension top mount bushes (poly), shocks/springs (coilovers)
also will have everything inspected ie ball joints, wheelbearings etc. etc. etc.
if that dont sure it... f**k kows what will
Adam Graham
06-09-2015 06:04 AM
