computer hacked
Old Mar 3, 2007 | 08:47 AM
turbo1973's Avatar
turbo1973
Default computer hacked
is there anyway of telling if your computer been hacked mine been really slow and making noises like it doing something
Old Mar 3, 2007 | 08:53 AM
BigMouthBillyBass's Avatar
BigMouthBillyBass
right click on the windows task bar and go to task manager, see whats using all your CPU and memory. that'll be what is making the hard disks go crackers ! post the processes up here and we'll see if we can help you out as to what they are.
Have you got any bittorrent running? i know ABC bittorrent client thrashes the fuck out of your disks and CPU, i switched to using uTorrent and its loads better
Old Mar 3, 2007 | 09:00 AM
turbo1973's Avatar
turbo1973
not sure what to do
Old Mar 3, 2007 | 09:12 AM
BigMouthBillyBass
Originally Posted by turbo1973
not sure what to do
If you go into processes you can see whats using your memory up. it's in the right hand column. if you click on the top of the column you can sort them high > low.
you'll see something like
firefox.exe <username> 00 32,765KB
the figure at the end is how much memory it is using, the ones with higher numbers are the important ones and are most likely to be the ones that are thrashing the tits off your disk
Old Mar 3, 2007 | 09:15 AM
rsnutters1's Avatar
rsnutters1
51,078k on firefox. is that about right ?
Old Mar 3, 2007 | 09:18 AM
turbo1973's Avatar
turbo1973
cant find it how do you get the taskbar
Old Mar 3, 2007 | 10:10 AM
PastyKing's Avatar
PastyKing
press control+ alt +delete then click on the process tab
Old Mar 3, 2007 | 10:14 AM
BM08's Avatar
BM08
Thats fine
Old Mar 3, 2007 | 10:16 AM
BM08's Avatar
BM08
Remember to show us a screenshot of it to save you typing it all out, when its on screen hit the print screen key, open up windows paint, press edit at the top then paste, save the pic and post it up
Old Mar 3, 2007 | 10:24 AM
rsnutters1's Avatar
rsnutters1
is there anything dodgy on mine
Old Mar 3, 2007 | 10:41 AM
patchST's Avatar
patchST
Have you ran a spyware scan and how much free hard drive space have you got on your machine, if you run out of hard drive space the Page File and the Master File Table get really fragmented which can slow your machine down and will need a good defrag.
Old Mar 3, 2007 | 10:43 AM
turbo1973's Avatar
turbo1973
found it but not able to print it on to screen can you explain what i do now
Old Mar 3, 2007 | 11:27 AM
PastyKing's Avatar
PastyKing
make the process box full screen, then hit the Print screen-SysRq key (next to scroll lock)
then open MS paint
then go to EDIT
then click paste
Old Mar 3, 2007 | 11:45 AM
turbo1973's Avatar
turbo1973
nothing happens
Old Mar 3, 2007 | 12:55 PM
DanRSturbo's Avatar
DanRSturbo
You may need to press alt + prt screen together, then paste it into MS Paint and it should capture everything
Old Mar 3, 2007 | 04:20 PM
BM08's Avatar
BM08
Short of goggling every process you cant tell 100% but just from scanning through it i cant see anything that seems fishy, plus 32 processes is pretty normal anyway, i wouldn't worry
Old Mar 3, 2007 | 08:42 PM
rsnutters1's Avatar
rsnutters1
cheers mate
AJC
Oct 1, 2015 06:47 PM
Kam B
Sep 24, 2015 10:40 AM
