HELP HELP HELP.... Car Mechanics.
Please, does anyone know why the Fanbelt on my Mk3.5 Fiesta Diesel would keep coming loose and squelling its arse off within a week of driving...
I have fitted a New Alt' Bracket, New Star Adjuster bolt thingy, Used New Locking Nut and Bolt for the Alt Bracket.... oh and of course New Belt cos the they keep slipping off....
Cheers guys.. So the problem could be way past the belt and securing items.
abdr500: Do you mean the Bottom Pully or the pully on the Alternator?
I can get an Alternator, but its only me run-around, so dont wanna spend tons of cash on it. Ł120 for an alternator is lot to gamble if it aint the problem.
Rs Baz: How do you tell if the shaft on the Alternator is bent? The Alt' Pully spin quite freely.
Have you got a belt on now? If you have, start the engine and have a look at the pulleys when they are turning to see if any are damaged/buckled (bent shaft) and all are aligned with each other.
With the belt removed inspect the pulleys for damage in the groves. Spin the pulleys and check each is smooth and there is no forward/backward (thrust) play.
If the belt definitely coming loose? It could be getting contaminated by oil, pas fluid etc and causing it to slip.
definitly no PAS Fluid (no PAS on the car) and havent got an oil leak anywhere. the area of the belts/pully is bone dry...
but i have to tighten it up again this weekend, so will the alignment and if theres any sideways movement...
the ALT pully is spinning nice and freely... obviously dont know about the bottom pully as that only moves when the cars started..
Ive half temped, just to get a new bottom pully and alternator fitted.
as moonie says mate start it up and let it run see if you can spot any
damage on the pullys as its on idle, you will notice if there is any damage
to the pully's
to the pully's
I re tightened the belt with the star tensioner thingy n see how that goes, n i marked the bracket to see if its the bolt that moves...
But i didnt see no obvious damage with the engine running, both pully's seem to spinning quite true...
Im partially stumped.
Originally Posted by Rs Baz
have bothe bolts got locking nuts on if not
replace them with locking one's
2 days of driving, been ok so far after tightning the tensioner star bolt. but normally starts to squel after about 4 days.
Thanks for the help guys, I seem to have sorted it..
have gone a week and a half without the belt sounding like a pig having a romping session...
I adjusted the star tensioner instead of just the usual tightening routine with the bar yanking the Alternator back... This seems to have solved it and kept it taught...
its either that or the Tip-Ex i put on to see if it was the bolt moving and coming lose that is holding it tight...
I reckon its the Tip Ex.
steerfromdarear
28
29-01-2016 06:14 PM
Stu @ M Developments
41
21-08-2015 06:47 AM
