Cossy ECU/Sensor Experts
Can u run a 32/36 position pickup on a P8?
Basically for running a FRST flywheel pickup for the crank signal.
or does it have to be a 4 position pickup?
Ryan
Ryan
I had the same issue with my XR2T, i tried an 1800cvh pulley and machined the lug's off just leaving the 4, but you need to file a new keyway in the middle of the wheel, as were the lug on the wheel is missing for the 1800 crank sensor you need a lug if you use the 1800 sensor bracket,
It was a real pain in the arse due to space, As i've now got a SECS S8 ECU i just used a standard 1800 wheel as it can run 4 or 32minus1 set up.
Hope that makes sense
Spanner monkey
Then lock it off with grub screws!
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
