KA engine, help settle a arguement
Old Sep 10, 2004 | 07:55 PM
MarkyMark's Avatar
MarkyMark
Default KA engine, help settle a arguement
Guys
need help to shut someone up
The Ka engine, 1.3 and 1.6 8valvers are (losely) based on the oldkent engine?, just recently rebranded as a duratec and endura before that?
Please confirm or not?
Old Sep 10, 2004 | 07:57 PM
jonesymk2's Avatar
jonesymk2
i think the endura e engine was loosly based on the old
kent engine but not to sure about the new engines now
Old Sep 10, 2004 | 08:00 PM
mark's Avatar
mark
think thay where based on the x-flow engine not the kent
Old Sep 10, 2004 | 08:05 PM
jonesymk2's Avatar
jonesymk2
the kent engine is the x-flow just sum people call it that
Old Sep 10, 2004 | 08:07 PM
~nomad~'s Avatar
~nomad~
yep its a kent (x-flow) basically.
mark's Avatar
mark
i thought thay was different o well learn sumthing new and all that lol
Old Sep 10, 2004 | 08:23 PM
MarkyMark's Avatar
MarkyMark
anyone confirm it for sure?
Old Sep 10, 2004 | 10:29 PM
MarkyMark's Avatar
MarkyMark
btt
Old Sep 11, 2004 | 12:13 AM
azcam's Avatar
azcam
As far as i know the endura e used in the earlier Ka is based on the old kent/crossflow unit first seen when Anglias and the like roamed the streets. It just evolved with fuel injection and better head design etc. The main thing is though that the 1.3 endura-e is an 8 valve ohv engine. The later 1.3 and 1.6 duratecs are 8 valve sohc (completely different engine).
I could be wrong but i think this is pretty accurate,
Alan
Old Sep 11, 2004 | 09:05 AM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
i think youll find it is based on the ford hcs engine
Old Sep 11, 2004 | 10:47 AM
BigNige's Avatar
BigNige
GUS
They are correct 100% the earlier Kas are DEFO a kent engine
newer ones ie last couple of years arent
Nige
Old Sep 11, 2004 | 10:55 AM
LPS's Avatar
LPS
It started life as the bobcat engine in the mark 1 & 2 fiesta's and the ford altered the valve layout and renamed it the valencia engine (built spainish factory) for the mark 3 fiesta and 4&5 escorts which ford improved it again and changed the name to the HCS unit and now ford have put a different rocker cover on it and multipoint injection and called it endura. But the block is basically the same
Old Sep 11, 2004 | 12:02 PM
Rs Gus's Avatar
Rs Gus
thank you they are NOT kent crosflow engines they are a totaly different animal the kent engine is about a inch or so longer than the valencia/hcs engine so NIGE
Old Sep 11, 2004 | 01:37 PM
BigNige's Avatar
BigNige
GUS back to ya
Overview
Fords legendary Kent Engine first appeared in 1959 in the equally new Anglia 105E. The Kent engine was completely new and finally allowed Ford to break away from its old sidevalve unit which powered the previous 100E small car range. Over the years Ford have continued to develop the Kent engine and have produced it in a huge range of sizes.
Other models to enjoy the Kent engine have included the Classic, Cortina (MkI to MkV), Capri, Escort (MkI to MkV), Fiesta (MkI to current) , KA, and small versions of the Sierra. The current versions of the Kent can be found in 1300cc form in the current Fiesta and KA, both types having Electronic Fuel Injection and catalyst converters.
http://www.motorbase.com/engine/by-id/20/
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
