Ackermann angles / Geometry
Old Feb 26, 2007 | 09:51 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Default Ackermann angles / Geometry
No anywhere near my 3door at the moment to look, can anyone tell me what sort of ackermann angle the steerings arms have.
Ie do they meet at the rear diff, or converge somewhere else, or not at all?
Thanks in advance
Chip
Old Feb 26, 2007 | 09:59 AM
WTF
Your asking university type questions on a Ford site? ..
..WTF is an ackermann?
Old Feb 26, 2007 | 10:02 AM
Chip's Avatar
Chip
Phil, I just want to know what way the steering arms point basically mate.
ackermann = german who died 100 years or so ago.
Old Feb 26, 2007 | 10:05 AM
...and whats he got to do with steering joints?
Old Feb 26, 2007 | 10:06 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Originally Posted by Bosch-Man
WTF
Its suspension geometry.
If you asked on somewhere that people know about suspension (ok, only forum i know like that is driftworks) itd be no problem.
Just on here race suspension is limited to "fit some polybushes and slam it on konis bruv"
Old Feb 26, 2007 | 10:10 AM
Chip's Avatar
Chip
Damn, saw stavros as the last reply and thought I might be getting an answer that was useful, lol
Im sure there must be a few people on here that know
Old Feb 26, 2007 | 10:19 AM
IAIN ABZ's Avatar
IAIN ABZ
Ackerman angle is a function of toein/out and steering arm length, the arm length is usually fixed (unless you are making your own parts???) and the ackerman angle will then be dictated by whether you want/need to run toe in or toe out...
This is assuming you are using a normal rack and are not moving it too?!?!?!?! A quick rack will make no difference but a rack with a different throw will, also if the rack is re-positioned it can affect the throw that the steering arms see.
Old Feb 26, 2007 | 10:24 AM
AlexF's Avatar
AlexF
Its normally about 7.5 degree iirc
Why are you planning on playing with it?
Alex
Old Feb 26, 2007 | 10:25 AM
Chip's Avatar
Chip
Yes mate, thats all correct.
My question is simply that on a standard cossie, with standard toe-in settings, what is the angle of the two arms in terms of where would they converge if you were to extend an imaginary line along them.
Ackermann obviously states that they should meet at the rear diff, but theory has moved on a long way since then, so im just interested as to how closely the cossie does or doesnt follow his principles.
Old Feb 26, 2007 | 10:26 AM
Chip's Avatar
Chip
Alex
Im not planning on playing with it at all, I just want it as a well known car as a point of reference.
Cheers for the 7.5 degrees info
If you know it for any other cars that are common (3 series? S14 200sx) that would also be cool
Old Feb 26, 2007 | 10:30 AM
AlexF's Avatar
AlexF
As for phil's comment
its a piece of basic car suspension theory.
http://en.wikipedia.org/wiki/Ackerma...ering_geometry
my 16 year old apprentice mechanics learn it in their 1st year of college!
Alex
Old Feb 26, 2007 | 10:31 AM
AlexF's Avatar
AlexF
I'll find you a definate on a certain car today Chip
Alex
Old Feb 26, 2007 | 10:32 AM
Chip's Avatar
Chip
Thanks Alex
IAIN ABZ's Avatar
IAIN ABZ
Cool, Chip...Sorry man i had no idea what it was on a cossie to be honest! But i do now...Cheers AlexF
Old Feb 26, 2007 | 10:42 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
IIRC Mk2 RS2000 is 4degrees.
Old Feb 26, 2007 | 10:44 AM
Chip's Avatar
Chip
Thanks Steve
dont suppose you can find out what it is on a S14 as these handle very well
Old Feb 26, 2007 | 04:39 PM
focusv8's Avatar
focusv8
To what extent do Ackerman's principles get modified when you introduce Passive rear steer into the equation?
Old Feb 26, 2007 | 05:03 PM
GARETH T's Avatar
GARETH T
now theres a question
steering geometry is my weakness with cars but im learning all the time
Old Feb 26, 2007 | 05:23 PM
...whoosh over my head
Old Feb 26, 2007 | 05:27 PM
ian sibbert's Avatar
ian sibbert
Ackerman's theory is all very well...but it only really applies at low speed...dial in weight transfer, tyre and bush deflection on a road car and ackerman goes out the window pronto....
Although the principles of drift cars probably do vary dramatically in comparison to cars which need to set fast lap times....
Is is not the acheivement of a dramatic steering angle thats necessary?
Old Feb 26, 2007 | 05:39 PM
Chip's Avatar
Chip
Absoultely agree that exact ackermann angles are not what most modern road cars use, far more relevant to low speed saving of tyres than performance, in fact in some cases tyre dynamics can actually lead to the use of NEGATIVE ackermann on certain types of car.
Old Feb 26, 2007 | 06:09 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
In what way?
Far as I see a professional drift car has similar settings to a normal circuit car.
Pretty much zero toe front and rear, more camber front than rear but ideally nor a huge amount of either (just enough extra front to stop any severe understeer), and plenty of castor to give good self centering.
Diff settings are about the same too, as are tyre sizes.
More steering lock is usually acheived with steering mechanics mods rather than geometry changes.
Old Feb 26, 2007 | 06:32 PM
ian sibbert
Steve,
It was actually more an assumption than a statement...never had anything to do with setting up drift cars....and as they spend most of their time on lock I would have assumed more steering angle was important...rather than optimising geometry....
Old Feb 26, 2007 | 06:56 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Lots of lock is important, but to win anything you need to be able to drift at higher speeds than everyone else (as once in the last 16 its basically a race), so huge amounts of grip are important, so its the same basic principles as a circuit car.
Good example is the Yoshio Factory D1 S15 has done a 59sec lap of Tsukuba Circuit, a McLaren F1 has only managed 1min 4sec at best.
Old Feb 27, 2007 | 12:42 PM
Chip's Avatar
Chip
That is bloody impressive stuff Steve!
Old Mar 1, 2007 | 02:40 PM
AlexF's Avatar
AlexF
about 2 degrees!!!
not 7
just been through a couple of 3 series of diffrent models on the wheel alignment machine....
Alex
Old Mar 1, 2007 | 02:42 PM
Chip's Avatar
Chip
about 2 degrees!!!
2 degrees per arm from parellel with the centre line of the car?
Or 2 degrees relative to each other (ie 1 degree per side)
Old Mar 1, 2007 | 03:12 PM
AlexF's Avatar
AlexF
the ackermann angle is two degrees
so 2 degrees difference between the arms as you turn.
Old Mar 1, 2007 | 03:22 PM
Chip's Avatar
Chip
2 degrees when you turn how many degrees?
The more you turn the more it will vary if they arent parellel
That doesnt make any sense just on its own
Old Mar 1, 2007 | 03:25 PM
AlexF's Avatar
AlexF
its usually measured at 20 degrees off centre in either direction
Old Mar 1, 2007 | 03:29 PM
Chip's Avatar
Chip
Ah thanks for that.
Im still going to have to do some trig now to work out what that implies about the arms themselves at rest though, lol, and i will need to know the toe in to start with too.
Fundamentally though, sounds like they must be very close to parellel in the first place which kind of answers my question roughly anyway
landaqmabba
Sep 15, 2015 07:16 PM
JesseT
Aug 30, 2004 01:19 PM
Neil S
20
Aug 11, 2004 08:41 AM
Jul 30, 2004 09:03 PM
neilm
Nov 3, 2003 12:39 PM
