Problems with 16's on a Mk3 Fiesta
Got a set of 16's to go on my RST
Anyone else had problems with theirs?? As in scrubbing on the arch etc?
The tyres on mine are 195/40/16's and i've stil got standard springs on the car
You will need your arch lips cut off and some of the plastic on the arch extensions cut off aswell to stop the rubbing.
Im running 195/45/16's and they were a right pain to stopt the scrubbage but i got there eventually. Will still rub slightly four or fives up but not constant just slightly over big bumps or when giving alot or welly round corners.
Mine are on 195/40's though which i've been told should be ok... someone mentioned i may need spacers but wouldnt need to cut any of the arch away
Originally Posted by SassyRS
yeh you could put spacers on ...
Just put them on and see![Top](https://passionford.com/forum/images/smilies/smile011.gif)
![Content](https://passionford.com/forum/images/smilies/content.gif)
Defo check before u get all the paint done tho..
ive had loads of mk3 fiesta's & the biggest problem is the wheel scuffing the suspension on 16's so a second hand set of konis sorted that
i never done nothing with the arches tho
Originally Posted by vx220
if it rubs on the rear spring cups, you might be able to turn them round to clear...
if not, coil overs!
if not, coil overs!
if not, coil overs!
if not, coil overs!
if not, coil overs!
if not, coil overs!
If it's catching on the arches with those tyres and standard suspension i can't really see any way of getting round it other than trimming the arches
3dr cossie
Alloy wheels and ICE for sale
02-09-2015 08:58 PM
