ESCOS Fan switch Pin Outs??
Can any one tell me what each pin does on the standard escos fan switch please? Should be a 4 pin sensor / connector
I want to bridge it to a switch so that if it gets a little too hot i can flick it on and overide the fans.
Thanks in advance
Thanks in advance
You have 4 pins....
2 close together, 2 far apart.....
--A--B--
C-------D
A and B are one switch,
C and D are the other.
One starts the fans on low speed, the other on high speed.
Cant remember which one is which but try a piece of wire an short
them out and try. (With ignition on)
--A--B--
C-------D
Cool thanks simon for all your help
im presuming one will be considerably more different than the other ie noticable difference between the 2 speeds
Im also presuming that ideally i should be bridging the faster stage of the fans yeh?
james kiely
28-08-2015 08:58 PM
