Weight saving -
Right, apart from me loosing weight, how can I save more weight in my car??
All the interior is out, bar the dash and front door cards, and two 6kg seats.
But where do I go now to save some more weight?
Erm I'm guess it's around 910kgs now, (an equiviliant car with the same bits stripped etc comes in at 910kgs)..
Just don't understand how the Pug 106 boys get their cars under 850kgs, it's not as if the cars are much difference in size?
Did Someone Mention TUV
Originally Posted by bud-weis
perspex windows
lighter wheels make a big difference too
replacement panels like doors/bonnet
how light do you want it?
Football Cwazy
i suspect it's the metal used on the shell is lighter.
you can get replacement panels fairly easy,i'd do bootlid,bonnet,doors and fit perspex windows....that should save a big big chunk
Pugs are alot lighter standard. Crash in a 106 and then have the same crash in your zetec s. you'll be glad you're in the zetec s. As for weight saving lose your bloody 17's! Rotating weight of those is huge compared to a lightweight set of 15's. if you've got the car caged drill holes out of all the inside panels etc to get rid of as much metal as you can. As said, perspex windows. Lose the electric windows. Rear wiper etc. Fibreglass boot, doors, bonnet etc.
Originally Posted by 89XR2
As for weight saving lose your bloody 17's! Rotating weight of those is huge compared to a lightweight set of 15's. .
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
As for fibreglass panels, I can't find anywhere that does them for a Mk5 Fiesta........
Foglights can't be that heavy can they?
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
Rear wiper motor!
Anything that you don't need bin it. It all adds. up. Drill holes in your door handles anywhere that you can get rid of excess material do it,
Contact djm motorsport. they'll be able to make you carbon fibre bonnets boots etc. Probably work in fibreglass as well.
Its nice to suggest things - would hate to do it to my own car
As above - get wide core cutting drill bit and go mad lol. Do you get smaller alternators with enough output - must be a bit of weight in them. Alloy brake calipers are usually light from what i have seen - discs with alloy rotors but not too big - the list is endless
Are coilovers lighter than a standard setup?
As rich said - it'll lighten your wallet too
Fucking everything on this car ligthens my wallet, don't worry!
With regards to perspex windows, the car is still an every dayer too, so I'd end up with a steemed up rear window and none winding fronts?
Bin everything that doesnt have a use, with no dash in my corsa, and the clocks cable tied to the steering coloum bracket, 2 seats, and nothing else in the car i managed to get 781kg, with glass windows and steel body panels
and theres a few slilly lightweight novas running around, that have got fibreglass bonnet/boots/perspex etc weighing in at 650kg
i know there bean tins, but shows how much you can loose if you really go mental
Underseal
remove redundant brackets
ALL sound deadening material.
There's a few more KGs!
Then you could get some lighter brakes and suspension - in addition to all the stuff above!
Alex
Alex
No sound deadening in at all Alex, apart from the roof, but I didn't want to risk boiling the paint with the blow torch to get it off!
smaller alloy rad , electric water pump, ally flywheel, 140mm carbon clutch, plastic fuel cell, each one will only save a small amount of weight but when you add it all together u would be surprised,
My FRST is well stripped back. I stripped the shell and removed all the underseal, all the sound-deadening from inside, replaced the roof skin for a non-sunroof version, perspex windows with sliders, fibreglass tailgate, kevlar bonnet, front bumper gutted so its just a skin, heater & motor removed, electric window motors & central locking gone, fuel tank replaced with fuel cell, steering lock, igntion barrel etc gone, all unecessary wiring removed, set of magnesium-alloy OZ's, oh yeah and I've lost nearly 2 stone
Baby Cheesus
all depends how much you wanna spend, and how far you are prepared to hack up the shell lol
carbon bonnet, doors and boot, bumpers etc - will all prolly be one offs so like £5k lol
remove all sound deadening from the car
remeove the ABS, sterio, heated rear screen, rear wiper and associated wiring - thats good for about 25kgs alone
polycarb windows, im only doing the rear screen and rear quarters on mine to retain the glass fronts
cut out all non strngthening metal from the shell, around rear quarters etc
ditch the power steering and pumps, aircon, dash, door cards
do what phils mate has done and cut holes in everything lol
fit smaller wheels
get aftermarket brakes, not only will this give you better stopping power, but you will save about 15/20kg over the std cast stuff
coilovers
scrape off the underseal and paint with anti rust paint
fit a smaller alloy fuel cell
ditch the spare wheel
have a big shit
fit smaller wheels
coilovers
have a big shit
Ban[B][/B]ned
Without sounding nasty mate, I would love to see the difference in perfomance with Youngmatt in it, Do this and it might motivate you to loose weight.
Instead of loosing more weight how about gaining perfomance?
Instead of loosing more weight how about gaining perfomance? ![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
