A/F ratio
Well I hooked up a friends A/F gauge and at Idle it reads lean. It only has leds to tell you so I don't know the actual measurement. Also when we hook it up it doesn't always read. Could my O2 sensor be going bad?
here's a Q... what voltage/resistance/whatever should a lambda/hego read at lambda 1?
just need to check mine at idle, n only got a multimeter, not a gauge
to measure it you would need a multimeter with a high input impedance (so no moving coil meters)
S1
09-07-2004 06:36 AM
