gauge fitting on RST......
Hi guys. Could any one tell me how to wire an - oil pressure gauge and a
- water temperature gauge
on an escort rs turbo please. Apart from the obvious of the wiring them to lights etc. Where do i wire it to and where can it be found on the engine. Many thanks
oil pressure: you fit the sender on the back of the engine where you tee off from the original oil pressure switch (for an electrical gauge), for a mechanical gauge, tee off from the same point and run the line to the gauge in the dash
water temp:cut your bottom radiator hose, and fit the water temp sender and its alloy tpiece here, then run the wires to the gauge
hope this helps
hope this helps
thanks fella.
another question. Im running all 3 in the heather vent on a mk4 escort. whats the best power line to run them off. has to be ignition rather than illumination as they are stealth gauges. many thanks
take the top cowling off the steering column and run it to the igntion live on the barrel itself, if i remember right its the yellow wire.
Run the earth to somewhere near, like the radio earth
this is how i had my old gauges set-up on my RST
gchristophi
31-08-2015 10:36 PM
mrmann
20-08-2015 11:24 PM
