fao christian
fao christian
got some things id like to ask ,do you use your car every day ?and when your at brunts do you have a good go at the 1/4s im not saying that a 14sec is slow or anything but surely your car should be doing say 12.9 or maybe a bit lower??? just askin out of interest
#1 in Spelling Club
I could use it every day, but I don't. It is nice to drive.
The car is geared long for the top speeds, plus I am shit at launching, everyone knows that. LOL.
Having said that, Tim's is one of the only RST's that has been into the 12's. Paul R did it too, but that was a car that had short gearing and semi-slicks etc.
5.8 to 60 isn't far off the pace for a car of my spec that isn't set-up specifically for sprinting.
Originally Posted by Christian and Beccy
Originally Posted by AJ THE PF GOD
Post subject: fao chritian
Would that be Christian?
#1 in Spelling Club
Originally Posted by timrud
I always wondered why you get slow 1/4's but superb top speeds, I should of really thought about your gearing
Remember the car goes off the clock in 4th, which is a REAL 130mph.
Your terminals are quality, and TBH on a FWD I look at that just as much as the time
Mine does at 7500rpm 128 in fourth according to my little calculator thingy. So yours is geared longer
But my turbo is so small 7500rpm isn't the best place to be
Originally Posted by crazycage
my mate Paul did a 11.86 @ 10 of the best 2 years ago and a 0-60 in 4.68 @ the ford fair last year and we all no thats geared long
#1 in Spelling Club
could of been a problem with the timing because paul not got anywhere near that time since and i think paul runs the same gearing as christians but cant really compare different engines and power delivery..
could of been a problem with the timing because Paul not got anywhere near that time since and i think Paul runs the same gearing as christians but cant really compare different engines and power delivery..
i'm having the same problems but i hope to Rectify them before central rs national day
Originally Posted by Tim
ooooooohhhhhhhhh the 12,s club not many in it yet, more this year i think
i guess you have probably thought about using nitrous but everywhere your engine struggles nitrous would make life alot easier but then a proper nitrous setup not going to be cheap.
[quote="crazycage"]
i no tim done a 12.9 last year and Paul r ,thats why i asked why you havent done it thats all,and my mate Paul did a 11.86 @ 10 of the best 2 years ago and a 0-60 in 4.68 @ the ford fair last year and we all no thats geared long
no probs with timing gear as christian did a 161.1 on the same timing gear on the same day @ the dady thrash jan 05
well then i find it a bit strange Paul never got anywhere near that time before or anytime after the event and the timing gear which is used at the daddy thrash is different to the one at totb. At the daddy thrash the timing gear is runs in the car which does'nt happening at totb
his top speed was at the daddy thrash and his 1/4mile at 10 of the best
yeah i know that if Paul was getting mid to low 12s then i could understand achieveing 11.86 but i think the fastest time Paul has had is a 13 dead with his Terminals 11s are defiantly on the cards but he will probably have to drop to 15" wheels and maybe try nitrous especially with such a big turbo.
look think wot you like he did 179 and 11.86 1/4 i was there ,and its back on the old turbo
#1 in Spelling Club
Crazycage, not being funny, but just because you witnessed it, doesn't mean it's right. I'm not saying it's wrong, but there have been lots of spurious times recorded in the past that many people witnessed. Take Severn Valley's 11-second 1/4 mile from a few years back. That was definately bollocks.
Turboboss - That set-up was spec'd for one reason. Numbers. BHP and Top Speed. Both of which it delivers. Job done. As soon as I want to set a sprint time, it would have a smaller turbo and a Quaife 'box and 12 second 1/4's would be mine. The spec that was used at the PF thrash was untested and yes it is laggy. We will see what the next course of changes results in.
thanks
sean
#1 in Spelling Club
Crazycage - I'm not doubting his times, I don't really have anything to do with TOTB. Although, most of the times from TOTB have had doubts cast over them since the beginning.
I know very little else about Paul's car, but it helps if it has achieved the times, or close to, on a separate day and better still at a different venue.
My car has done circa 168mph at 2 different venue's and has exceeded 167mph at least 5 times now, so cannot really be disputed, for example.
#1 in Spelling Club
thanks
sean
Seriously. It doesn't help having had such a string of gearbox failures, it tends to make you a little gentle for fear of it breaking. I have also done very little with sprint timing, I can't even remember the last time I ran at Santa Pod. Every runway event, I am exclusively there for Top Speed, so any sprint times are purely by chance.
#1 in Spelling Club
