cosworth head bolts & long stud & wrc gasket Q
follow on from head bolt topic.I know its very hard to get hold of the genuine head bolts for the cosworth ..so what now??do we use the alternative ones people are selling the 10.9 ones and what are peoples thought on theses head bolts how many of you are running 500 bhp+ on std head bolts and I know long stud is best but this is why I am asking coz not sure what to do as there are people that run this power with std head bolts and 4 layer wrc gasket your thoughts please
saff is working!!!...atm
i have just done what i was told.....6 long stud (ahmed supplied) 4 used standard head bolts....mountune 3 layer steel gasket...good for mine..420bhp and more...
dave cos4x4
well the ones woodford sell are from cosworth as they said but they have 10.9 stamped on them and not the kx 1000 on them so i dont know now dave cos4x4
dont get it twisted now
2Evos & 1 Escort Van :-)
I'm going to continue using 10.9 ones as supplied by Burton (i have some in their packaging) and Matt Lewis, and Amber. Probably everyone other than MAD and Cosworth supply JUST the 10.9 ones.
Never had a problem with them, and until I see different (proper SCIENTIFIC tests rather than hearsay and guesswork) I'm not going to change.
Plus I'll still be on my Cometic gasket.
Si
Si
I was sure it was Mark @ MAdevelopments that said that the genuine Cosworth ones weren't the 10.9 stamped ones
Obviously there is only one headbolt now and no doubt if they supply those then they are fine to use
jon@work
the ones i got today are 10.9 ones and was told they are genuin i am happy to use them but what are head bolts like with 4 layer wrc gasket and 500 bhp [
Originally Posted by abdr500
jon@work
Did Someone Mention TUV
madevelopments
Can you anser my email please Mark
Woodford sell the 10.9 bolts, as i found out when i recieved mine. Not really Simon's fault as he is under the impression that they are the correct type. But he will refund you if you arent happy and dont want to use them as he has said to me
madevelopments
i c because the place i got mine form siad that ther are from cosworth and this is what cosworth are supplying now wood ford i think the place was
thank you 1 qusetion i gess alot of people want to know is alot of other tuners are selling or using these and all seem ok how come you wount totch them and isnt it a bolt grade that is made to the same spec as cosworth
Some further info from Cosworth Shop on-line:
HEAD BOLT - SMALL WASHER (EARLY TYPE) (YB0461) £2.20
http://www.cosworth.com/shop_item.php?productid=222
HEAD BOLT - LARGE WASHER (LATE TYPE) (YB0449) £2.00
http://www.cosworth.com/shop_item.php?productid=223
Mark
