best way to bleed a 4x4 cossie cooling system?
Old 08-02-2007, 04:26 PM
Gra
Gra's Avatar
Default best way to bleed a 4x4 cossie cooling system?
Can someone tell me the best way to bleed the system after fitting a radiator please as i want to make sure i am doing it correctly
cheers
Gra
Old 08-02-2007, 04:30 PM
Lloyd
escort mk4 cossy 4x4
Lloyd's Avatar
try undoing the bleed bolt on the thermostat housing
Old 08-02-2007, 04:39 PM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
As above. Make sure cap is off header tank. Undo bleed screw. Run engine until water flows continuously from bleed screw. Stop engine. Do up screw and top up header tank as necessary. Job done.
On a 2wd it is a nightmare to get out air-locks, as they don't have that bleed-screw to do this with .
Old 08-02-2007, 05:39 PM
Gra
Gra's Avatar
aye thats what i have been doing, but wanted to check it was the correct procedure,
cheers
Rob Wells
Ford Mondeo Including ST
18-04-2023 12:19 AM
ST-170
04-09-2015 11:02 AM
cossirob
03-09-2015 09:17 PM
StephTell
02-09-2015 06:31 PM
Quick Reply: best way to bleed a 4x4 cossie cooling system?
