were are the bolts that hold the front bumper on cossie?
04-02-2007, 11:46 AM
500bhp Cosworth in making
should there be 2 or 4?
and were are they cant see them or feel them
can someone give me some ideas
04-02-2007, 12:04 PM
If i can remember right, i think there's one on each end by the wheel & there's one on each clamp that goes into the chassis next to the fog light's (under the car)
I stand to be corrected as i havent worked on a cossie for years
04-02-2007, 12:25 PM
there are two 13mm bolts on either side of the bumper (on a saff) they are behind the wheelarch liner on the front bottom of each wing they usually seize and break your bumper so plenty of wd first..then the bumper just pulls off
04-02-2007, 12:35 PM
cable ties
04-02-2007, 12:36 PM
or a big self tapper drilled throught he wing!!!!!!!!!!
04-02-2007, 02:20 PM
04-02-2007, 04:02 PM
yep!! thats what usually greets you im afraid
04-02-2007, 04:03 PM
what should they look like?
04-02-2007, 04:43 PM
Resident Wrestling Legend
not like that, like this
i think pj do replacement plastic panels that replace the whole lot
04-02-2007, 04:46 PM
Quote:
Originally Posted by Roosie
see this pic? the wing will get sorted if you just strighten th emetal out
there should be a triangle there not a round hole, the plastic thing that supports the bumper and the bolt goes through just clips into place in this hole (it goes in and twists to lock into place)
hth
04-02-2007, 04:50 PM
yeah but my bumper still needs new bits either side
04-02-2007, 04:57 PM
you can get the bits from ford
around the £70 i think
i have to get them for mine
you could cheat if you want by pulling the bump strip away and drilling a hole behind it and using a long self taper into the wing then cover it up again with the strip
04-02-2007, 05:00 PM
is this a common thing that people do with the self tapper?
04-02-2007, 05:01 PM
Quote:
04-02-2007, 05:08 PM
Roosie
its cheap simple and does the job
but if you want to do it properly then get a new fitting kit
im having to buy 2 wings as my wings are rotten on that area so just replacing that bit with anew fitting kit aswell
04-02-2007, 05:17 PM
04-02-2007, 05:24 PM
if you do it make sure its a long screw
you will be surprised in how long it needs to be
04-02-2007, 05:30 PM
how much are the pj ones ?
04-02-2007, 08:28 PM
Quote:
last time i saw them i think they were £60 all in
05-02-2007, 12:28 PM
well looks like ill be doing the self taper idea
just phoned ford and they dont do them anymore
and just sold my last bumper and that had new side mounts on it
05-02-2007, 12:45 PM
im going to need a spacer between the bumper and wing when i tap it as its just going to pull it right in!
05-02-2007, 02:31 PM
ok just screwed
mine in now 2 each side lol i will post pics up later looks good actually
jessie_rs
11
03-06-2019 04:57 PM
andy130
15-03-2016 07:59 AM
Gary @ RS CLASSICS
11
10-09-2015 06:49 AM
xr4x4rs
06-08-2015 09:03 PM
