whats the advantage of using twin piston rings in a turbo?
not quite sure what you mean mate as turbos dont have pistons! are you on about the engines?as im sure you dont add piston rings when you add a turbo,please expand on what you mean!
Football Cwazy
what????
i can only assume you are talking about Twin Piston Dump valves,these are supposed to be for Escort Rs Turbo's..in truth they don't work well at all......Fiesta RS turbo's use single piston or Diaphragm type.
turbo shaft seals are referred to as "piston ring seals" as that's what they look like - metal sprung ring with a small gap for expansion. I'd imagine they are suggesting maybe double ones to reduce the potential for oil escape from the core ?
cheers guys
Rstar_man
143
20-07-2020 11:16 PM
Matt Baxter
16-09-2015 08:30 PM
