cossie V6
cossie V6
Does anyone know where i can get a cossie V6 and how much would it cost, also would there be any point in putting it into an escort? also i need to know what the base that was used for the escort cosworth (year and type)
cheers
cheers
v6s are cheap as chips,get a whole granada cosworth for a few hundred quid on ebay.i dont see any point at all putting it into an escort,its a 2nd rate cousin to the yb in my eyes. and the escos was based on the 4x4 sapphire cosworth.
Resident Wrestling Legend
the ford V6 escorts that you are on about were based on the escos chassis which is why everything bolted in almost directly, as the wigster has said, they were based on the saph which has the same sort of pick up points as the granadas
buy a whole granada 24V, chop the floor of and weld it to the escort
or call gartrac
or call gartrac
er...the v6 IS rwd!you wont find a front wheel drive one of these!,quaife six speed would cost eleventy million times more than the rest of the whole car!
just bolt it into a sierra if anything with a standard 5 speed unit.
the conversion is VERY good as a cheat bolt in conversion on a budget.
in my opinion it is THE BEST conversion you can do to any non-cosworth sierra.
if you're looking at spending a few quid or extracting any more than standard power, i'd reccomend you look at going YB.
i've thrown a LOT of money at a non-cossie v6 sierra, and for the same money i could have had a properly sorted 500bhp cossie
you can buy a decent 24V converted sierra for around the £2k mark or you can buy a nice sierra and then find anotehr few quid to get a granada and do the swap and it'll cost you lerss money but more time
don't forget the thigns like getting the brakes and suspension sorted for the bigger (much heavier) engine either, i put the 24V springs on the sierra and, with the normla twinkly lump in there it sat around a foot in the air i kept looking for the axle stands
Re: cossie V6
cheers
cheers
The escort cosworth shell is unique.
Its a shortened sierra floor pan with brand new designed panels.
The ONLY original escort body bit is the boot lid from a Mark 5
and possibly the fuel cap too.
Russ Payne
25-09-2015 08:29 PM
