Does a Series 2 clutch +flywheel fit a S1?
S1 Database Editor
Just agreeing with Gaz. Straight in mate. Did mine when I had a slight weep from the g/box. Had all new seals fitted and fitted a skimmed S2 flywheel with new S2 clutch. Still fookin slips slightly tho if you pootle along then boot it in 5th
S1 Database Editor
Yes, proper Ford clutch.
Apparently they're geared to handle 16psi+ and around the 200bhp mark from what I could gather on other threads about clutches.
Mine runs 1 bar (14.5psi) with unknown bhp or torque (more than standard) but will slip slightly as I say. If you go through the gears it's fine but if you're in 5th then it slips as the boost comes in.
09-10-2015 07:38 PM
hazbaz1984
Ford Focus (All Models)
30-07-2015 05:15 PM
