amd cpu failed. pics
Old Jan 28, 2007 | 05:27 PM
morto's Avatar
morto
Default amd cpu failed. pics
hello all has any one ever had a 64bit amd get that hot that when i tryed to get it off the cooler it had welded its self to it but they have 3 year warranty on them
as hard as i try it wnot come off
andy
Old Jan 28, 2007 | 05:34 PM
ECU Monitor Enthusiast
Its not welded.
This is physically impossible as you would need to get to 900+ deg C
to melt alumininium
The cpu is bonded to the heatsink to improve heat transfer.
On some chips the heatsink CANNOT be removed without destroying the
CPU chip so best make sure it has failed !
Old Jan 28, 2007 | 05:36 PM
BigMouthBillyBass's Avatar
BigMouthBillyBass
Default Re: amd cpu failed. pics
andy
if it wasnt fucked before it probably is now
Old Jan 28, 2007 | 05:43 PM
morto's Avatar
morto
my mates got the same motherboard as me so i will put it in his, ive tryed changing everything else, ram, hard drive and vga, b4 taking the cpu out, if not it could be the motherboard, but i did smell burning
andy
Old Jan 28, 2007 | 05:47 PM
BigMouthBillyBass
Whats it doing? does it boot up and then blue screen, or does it just beep when you turn it on??
Old Jan 28, 2007 | 05:51 PM
89xr2's Avatar
89xr2
Brap!
It's just the thermal compound sticking it on. Can be a right cunt to get off.
Old Jan 28, 2007 | 05:56 PM
BigMouthBillyBass
look at the capacitors and see if any are leaking, or look like they are going to burst
in case you didnt know, they look like this
Old Jan 28, 2007 | 06:11 PM
morto's Avatar
morto
it wont get to boot just black screen , so im fooked.. its ither mobo or cpu, ive checked everything else, its the burning smell that makes me think mobo, but fook nows
andy
Old Jan 28, 2007 | 06:13 PM
BigMouthBillyBass
Does it POST?
Old Jan 28, 2007 | 06:15 PM
Eagle's Avatar
Eagle
Super Moderator
to help .. its a bugger when they do tho .. easily replaced with a soldering iron..
Old Jan 28, 2007 | 06:16 PM
morto's Avatar
morto
no doesent post
Old Jan 28, 2007 | 06:17 PM
BigMouthBillyBass
any beeps from internal speaker?
Old Jan 28, 2007 | 06:18 PM
Check the PSU..... Have a sniff of it to see if thats burning.
Probally the cheapest/easiest part to replace
Old Jan 28, 2007 | 06:20 PM
morto's Avatar
morto
no beeps,and the fan on the psu is runnig, and the fan on the cpu running
Old Jan 28, 2007 | 06:21 PM
BigMouthBillyBass
If it's in a cheapo case it's very likely, as the PSU's you get in 20 quid ATX cases generally only last 6-12 months, especially out here we get loads of surges and power cuts and ive had two go. invested in a decent quality one and its been fine for 18 months
Old Jan 28, 2007 | 06:22 PM
BigMouthBillyBass
Doesnt mean anything. the voltage lines that supply the fans might be OK. all the other lines could be fucked. or maybe just one or two, change the PSU and see
Old Jan 28, 2007 | 06:24 PM
Eagle's Avatar
Eagle
Super Moderator
any chance of some pics of the mobo ????
Old Jan 28, 2007 | 06:26 PM
morto's Avatar
morto
i can change the psu from my mates, but my problem is ..how do you get the cpu back on the board if you cant get it off the cooler? its a socket 939 64bit 3000
Old Jan 28, 2007 | 06:37 PM
Redeye Jedi's Avatar
Redeye Jedi
Ive had a similar problem and mine turned out to be PSU failure! Id try plugging in another before butchering your CPU anymore!
Old Jan 28, 2007 | 06:38 PM
Eagle's Avatar
Eagle
Super Moderator
if its that well secured to the heatsink... how did you remove it ??
Old Jan 28, 2007 | 06:46 PM
morto's Avatar
morto
the pins on the cpu look ok, as i pulled the cooler off the cpu came with it, but as you now thers a lever you should pull first to get the cpu out, the lever was still inn the down position, surely the cpu shouldent be that secure to the cooler? if so its amd,s fault, ive had loads of cpu,s off and seen none like this ..
Old Jan 28, 2007 | 06:49 PM
Jim Galbally's Avatar
Jim Galbally
ive done that. it shouldnt damage the pins
Old Jan 28, 2007 | 06:52 PM
st3v3's Avatar
st3v3
Its not welded.
to melt alumininium
660.25 deg C is the melting point of Aluminium
Old Jan 28, 2007 | 06:54 PM
st3v3,
Thanks close enough
Old Jan 28, 2007 | 07:02 PM
BM08's Avatar
BM08
ive got the AMD 4200 X2, never had to take my heatsink/cooler off before though so im not sure.
Why did you take it off in the first place?
Old Jan 28, 2007 | 07:40 PM
morto's Avatar
morto
to look at the top of the cpu to see if its been overheating, iv seen chips fail b4 and they look a differant colour as the heats got to much,
andy
Old Jan 28, 2007 | 07:46 PM
BM08's Avatar
BM08
it wouldnt be overheating unless 1. you overclocked it too much or did it wrong, or 2. if your case is cramped and has little airflow.
Why dont you use a programme to monitor the temps, i use Everest, its free and its pretty accurate
http://www.filehippo.com/download_everest_home/
Old Jan 28, 2007 | 08:51 PM
JamesH's Avatar
JamesH
Providing you don't solder a new one in the wrong way round
Old Jan 28, 2007 | 09:08 PM
DanRSturbo's Avatar
DanRSturbo
Righto, no POST beep's often results in CPU failure, possible motherboard, either way, don't put it on another motherboard unless your m8 is a real forgiving bloke and willing to sacrifice his system.
Burning smell could possibly be a PSU on it's way out, so I'd buy a 450 watt + true power psu. By all means buy a cheapo one, but dont complain if it doesn't do the job
Providing you bought the cpu from a good retailer, (unlike Eagle and his P4 saga from E-bay ) send it back and get a replacement, I would also buy a fan designed for a cpu of a higher spec
In the event of the replacement CPU not working, then it'll probably be new cpu + motherboard
Old Jan 28, 2007 | 09:13 PM
Mark V8's Avatar
Mark V8
I replaced my AMD CPU and the motherboard before finding out that my PSU was no good, the fan worked as well
Mark
Old Jan 28, 2007 | 10:03 PM
jammy86's Avatar
jammy86
Looks like someone has used Thermal Adhesive rather than Thermal Paste on that cpu. It probably wont come off. you could try some Arctic Cleaner, though i doubt it'll work.
JAmes.
Old Jan 28, 2007 | 11:08 PM
saphycozzie-adz's Avatar
saphycozzie-adz
just slip a fine blade or scalple under the cpu and base of cooler. easy
Old Jan 28, 2007 | 11:19 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
pmsl you can blatantly see that has far to much heat sink paste on the processor just by looking at it.
I regularly over volt and overclock processors, I've done 100% overclocks in the past and have never ever had a processor die from over heating.
EMT64 Athlons have a maximum operating temperature of at least 65°C with most having maximum operating temperatures which exceed that.
I would bet mobo death as that heat sink is a OEM POS and as such I would expect came of a similar mobo
Old Jan 29, 2007 | 09:41 AM
morto's Avatar
morto
your wrong mate, the new 64bit come with the right amount of paste all ready on from amd...
thanks
andy
Old Jan 29, 2007 | 10:10 AM
morto's Avatar
morto
its off as you said, so now i can test the cpu
andy
Old Jan 29, 2007 | 12:07 PM
BM08's Avatar
BM08
Like i said above why not just check the temps with a programme, theres no need to take the cpu out just to decipher if its got too hot or not
Old Jan 29, 2007 | 12:20 PM
Turbocabbie
Top Cab !!
thanks
andy
Don't think so... not all the only processors that come with a thermal heat transfer heatsink pad from AMD are the retail processor in the box, the OEM processors and those shipped to developers and system builders do not.
The pictures in the appropriate AMD PDF document on this most certainly does not display heatsink transfer pad or paste leaking excessively out the side of the join... this indicates too much material being present unless of course AMD are also wrong.
http://www.amd.com/us-en/assets/cont...docs/26951.pdf
Old Jan 29, 2007 | 12:25 PM
morto's Avatar
morto
it is retail
as said thats the right amount of paste on as sent by amd
Old Jan 29, 2007 | 12:46 PM
BM08's Avatar
BM08
HELLO? can you see me , can you see what iam typing!!
Old Jan 29, 2007 | 01:44 PM
Turbocabbie
Top Cab !!
Wow im surprised you recieved that much themal pad material on the sink from AMD never seen that amount before in a retail box, even now it looks excessive to me.
I would personally lap that sink to improve heat transfer and use artic silver for the paste.
