Quick plumbing question to all plumbers and general diyers
Ive just put an offer on my future house but theres one problem, the wolly has got rid of the bath and fitted a shower (i dont do showers!)
My question is i want to put a bath back in (the same place where the shower is now) how much would i be looking at roughly in labour if i perchase the bath?
Cheers folks
Cheers folks
Without seein the job mate its hard to say,but asuming theres room for the bath it should pretty much be a straight swap and should be able to use the cold feed and waste that is already in place from the shower. Also assuming theres a sink nearby then that could supply the hot feed for the bath!
If all goes to plan then should only be charged a days labour, which depending on company should be around the £200 mark!
try and do as much of the work as u can your self like taking out the shower tray takin off tiles and any wood that might be in the way.do that the night before an they should be out by lunch time.
With how good push fit fittings and plastic pipe are, there is no reason that if you know one end of a spanner from the other you shouldn't do this yourself. It's 3 pipes FFS. Probably even find both feeds for the taps are under the shower tray capped off
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
andrewmctiernan
08-09-2015 03:05 PM
