mondeo tdci's
mondeo tdci's
looks like these well equiped cars are good for mile munching, what do i need to look out for? i know thw the 130bhp is the one to get,
anything i should walk away from and any particular mileage i should walk away from too?
cheers
cheers
I've worked a few, most high mileage (taxi's) there seem pretty good started motors do go on a few and some time's if the clutch is crap it'll also need a fly wheel there not cheap. apart from that just normal stuff anti roll bar links and rear subframe bushes, they have finaly got a front lower arm that doesn't need replacing every other service like the mk 1
+2's and there's no cambelt to worry about
Try and stick to under 120thousand miles and you should get something worth keeping for a couple of years.
Good for mileage as long as you keep up on the basic, oil, fuel and air filters, and oil of course.
i plan to keep it a while but i know when uni finishes il be searching for a cossie again, a bit like im doing now
yeah i totally agree diesel engines go on for ever with fresh oil
Originally Posted by ultimate sleeper
sounds good, i take it the flywheel and clutch is cause of the torque?
missed out on a good one at auction today i couldnt beleive it
is it on a cam chain?
my cousin has the 130bhp model on a 52 plate. I drove us home last night as he had a drink and drove it today also. Its really nice to drive, has leather heated seats and all sorts
I'd love an ST TDCi
I'd love an ST TDCi
rear axle bushes are common for wear , watch for pump failure and front springs are becoming common, also check heated washer jet wiring , i had one set on fire on me .also rhr caliper is left hand thread if you do pads some people think there knacked and there not
it was at a live real auction mate
if i give u 3k deposit can i buy your car off u??
what will that bring it up to? sounds good
130bhp + 25 = 155bhp
OR
130bhp + 30 = 160bhp?
i meant torque, i shudv put that
In my opinion there isn't much between the the 130 or 150 until top end, the 150 really comes into it's own in 6th when you nail the throttle and you take of just the same as you did in third!
But obviously you won't be doing that often which makes the 130 the better all rounder.
It's a fairly good car though, just watch for start-up clattering, poor starting when cold and clutch judder as all will bring expensive bills.
Passats, and tdci 115 focuses are also very good diesels for similair money?
wowk
30-03-2021 07:49 PM
