PC HELLLLLLLLLLPPPPPPP
Old Jan 25, 2007 | 04:20 PM
Default PC HELLLLLLLLLLPPPPPPP
Got in and switched my main computer on and all it says is please put in a boot device
Put a win XP pro disc in and it loads files but then it tries to start but i get this:-
Blue screen writing with this
*** STOP : 0X0000007E (0xc0000005,0xF853D0BF,0xF8989208,0xF8988F08)
*** pci.sys - Address F853D0BF base at F8536000, Datestamp 3b7d855c
HELP???
Old Jan 25, 2007 | 04:22 PM
dvid's Avatar
dvid
Sounds like the blue screen of death to me but I am sure someone with more knowledge of this will confirm
Old Jan 25, 2007 | 04:23 PM
OK but whats packed up the hard drive or the board etc?
Old Jan 25, 2007 | 04:26 PM
dvid's Avatar
dvid
Can you re-start in safe mode? Normally a hardware or driver issue if I remember correctly
Old Jan 25, 2007 | 04:30 PM
No it does the same thing
Old Jan 25, 2007 | 04:32 PM
dvid's Avatar
dvid
I would wait for some more opinions really as I am not too clued up on all of this.... But it don't sound good
Worst comes to the worst try your hard disk as a slave in your other PC but like I said I would wait for other opinions first
Old Jan 25, 2007 | 04:34 PM
When i boot it says
Reboot and select proper boot device
or insert boot media in selected boot device and press a key
Old Jan 25, 2007 | 04:35 PM
DaveEscos's Avatar
DaveEscos
maybe its finally been hit by the guilt of being a fashioned instrument that has been the main tool that has let a grade A cock infect the internet!
Old Jan 25, 2007 | 04:37 PM
Says the man who shows his cock to the lads of passion ford
Old Jan 25, 2007 | 04:40 PM
DaveEscos's Avatar
DaveEscos
yes phil, but half of it was hidden in a girls mouth ....
( and it was hitting the back of her throat! )
Old Jan 25, 2007 | 04:43 PM
Can you prove that wernt Rainbird with a wig?
NOPE
Old Jan 25, 2007 | 04:51 PM
COME ON FOLK
Old Jan 25, 2007 | 04:53 PM
DaveEscos's Avatar
DaveEscos
NOT AT ALL
Old Jan 25, 2007 | 06:00 PM
patchST's Avatar
patchST
Reboot your computer with the xp disk, press r when asked to repair, and then choose your windows installation, you'll need to know the administrators password and then run this command from the command prompt chkdsk /r it usually fixes most BSOD errors.
Old Jan 25, 2007 | 06:08 PM
cheers but i have now got no screen i changed the display setting in the bios .....when i did before do as you said it still wouldnt load as it said enter the floppy disk..i aint got a floppy disk or a disk
HELP!
Old Jan 25, 2007 | 06:28 PM
L33 BYT's Avatar
L33 BYT
Phil, take out the power and reset the battery jumper on the mother board.
Hopefully that will bring your display back if you been messing with the bIOS.
The as above XP Disk. Press R then CHKDSK /R
Old Jan 25, 2007 | 06:42 PM
DanRSturbo's Avatar
DanRSturbo
Gentlemen,
Before you can run a windows XP disc on a machine, you need to assatain the actual problem. In this case :
This, coupled with the error message above indicates at first a hard drive problem.
Phil,
When the computer first comes on it will look like this
Press what ever key it say's to enter setup, usually DEL.
Once in there, (depending on layout and make of bios) there should be a standard cmos setup option ?
Now, this should give you the details of the hard drives / cd writers installed.
Basically, if you have 1 hard drive and 1 cd drive and only one thing is listed, then the hard drive is not being detected.
Now, press F10 to exit and save changes, switch the pc off, take the side of the case off and unplug the power cable from the hard drive, it's the yellow, black, and red cable that goes into the har drive (bad pic)
Now, plug it back in and switch it back on. If still no joy then It would be fair to say that your hard drive is fooked
Now, you could take it to a geek with computers to see if there's any way of getting the data off the drive
Old Jan 25, 2007 | 08:55 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
Default Re: PC HELLLLLLLLLLPPPPPPP
HELP???
The official responce from Microsoft when you search the knowledge base for '0X0000007E' is that you do not have all the fixes to fix the problems with service pack two which was introduced to fix the problems of service pack one which was introduced to fix....
http://support.microsoft.com/kb/839641
consider though that this information is coming from a company who make fixes to fix the fixes
Without more information about your system specifications I can only point you towards what Bill thinks is the problem
Old Jan 25, 2007 | 08:57 PM
Turbocabbie
Top Cab !!
HELP!
if you need a XP floppy disk you can get it from bootdisk.com ...
Old Jan 25, 2007 | 08:59 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
thats what you get when you use a non tuv approved computer
Old Jan 25, 2007 | 09:06 PM
Turbocabbie
Top Cab !!
I would remove ALL the devices the system does not need to run such as PCI network card, PCI sound card etc and then try to run the disk again.... you can always add these devices once windows is up and running
Old Jan 25, 2007 | 09:54 PM
FasterFords's Avatar
FasterFords
Originally Posted by DanRSturbo
that middle hard drive is going to cook and die
Old Jan 26, 2007 | 07:11 AM
Cheers guys but it DOES detect the hard drive in the Bios...will try some more tonight!..Its got about 20 films on it and a collection of dodgy naked women
Old Jan 26, 2007 | 09:15 AM
Turbocabbie
Top Cab !!
have you tried removing all the cards that the pc does not require to run ?
Old Jan 26, 2007 | 09:42 AM
...its all on board bar the graphics card.
Old Jan 26, 2007 | 11:22 AM
BM08's Avatar
BM08
Hard drive? the whole system is at risk seriously that needs sorting mate
What you want is a modular psu, something like mine
Old Jan 26, 2007 | 12:57 PM
DanRSturbo's Avatar
DanRSturbo
The system is fine chap's, and it has to be a little untidy with 7 hard drives in it, and 2 fan's on the back, fan on the graphics card, and an exhaust fan sitting below the graphics card
Pic to follow
Old Jan 26, 2007 | 01:10 PM
BM08's Avatar
BM08
You CAN get it more tidy if you had a modular psu like the one i have, then you only use the wires you want, instead of having loads of unused wires clogging the case up.
I expect you dont really care if it works ok but im just saying there is a way to get it looking better even with all your hard drives
Old Jan 26, 2007 | 01:14 PM
DanRSturbo's Avatar
DanRSturbo
That is how it looks, now, bearing in mind there is, 7 hard drives, 1 dvd rom, 1 dvd rw, 2 fan's on the back, a graphics card that needs power, and the exhaust fan that's underneath the graphics card that requires power, short of cable tying everything together, there's no real way to tidy it up, bearing in mind I am often switching hard drives
Current CPU temp is 47 degrees
Old Jan 26, 2007 | 01:22 PM
BM08's Avatar
BM08
That is rather warm 47, my AMD X2 4200 is about 33-34 after 2 hours of playing battlefield 2142 online.
But you should still be ok at that assuming you have AMD as they can run pretty warm.
EDIT, what would you do if someone nicked your tower with all your HDD's, your life is on there by the looks of it
Old Jan 26, 2007 | 01:25 PM
DanRSturbo's Avatar
DanRSturbo
Of course I have AMD, don't you read any of my post's
Edited for the added extra question
Even if you did nick the tower, there are security measures I've put in place
Old Jan 26, 2007 | 01:28 PM
MY POST.....HELP ME
BM08's Avatar
BM08
I thought you did, just didnt know if the above pic was of another pc or maybe you had changed it.
Alps Pacino's Avatar
Alps Pacino
Old Jan 26, 2007 | 01:41 PM
THE_J_OF_OWNAGE's Avatar
THE_J_OF_OWNAGE
my core2duo is the same :P
Old Jan 26, 2007 | 01:42 PM
THE_J_OF_OWNAGE
thats like a standard xr2i to my 800hp cossie
Old Jan 26, 2007 | 03:28 PM
BM08's Avatar
BM08
Old Jan 26, 2007 | 03:29 PM
BM08's Avatar
BM08
MY POST.....HELP ME
sorry
Think of it as a free back to the top aint it
