New product line.. whos interested...
Old 06-09-2004, 04:04 PM
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Default New product line.. whos interested...
There is a new product on the market and im interested to know who will be realistically interested in purchasing one.
Its a Weber Marelli serial output monitor thats fully compatible with all current forms of Weber serial comms.
(Note: Not standard weber flashlamp codes)
The monitor is available as a standard version and also as a professional version. The monitor displays real-time engine management parameters. These include;
Engine RPM (rpm)
Coolant Temperature (ºC)
Charge Air Temperature (ºC)
Boost Pressure (absolute) (bar)
Battery Voltage (V)
Throttle Position (º)
Ignition Timing (º BTDC)
Fuel Injector Opening Time (mS)
Sensor Fault Detection
4 channels of analogue data (optional)
The monitor works with ‘Ford Cosworths’ that run the Magneti Marelli L8 or P8 ECU if the correctly configured chip is installed.
The cost for this version is £325+vat
Pro Version:
The professional version has all this plus:
DisplaysCurrent Ignition Map Address
Displays Current Fuel Map Address
Blanket Fuel Adjustment +/-
Blanket Ignition Adjustment +/-
This gives you the ability to add and remove fuel and/or spark advance from the engine whilst its running.
The cost for this version is £400+vat
Old 06-09-2004, 04:07 PM
dannyblackpool
Boost Builder
dannyblackpool's Avatar
Old 06-09-2004, 04:08 PM
Tony Turbo
www.ctuceilings.co.uk
Tony Turbo's Avatar
Sounds pretty fucking good
Any pics?
Old 06-09-2004, 04:10 PM
DaveEscos
DaveEscos's Avatar
what does it look like??
Old 06-09-2004, 04:11 PM
peteh
peteh's Avatar
sound pretty cool
get some pictures up stu
Old 06-09-2004, 04:13 PM
Turbo lag
Turbo lag's Avatar
its not made by sec's is it because I would like it before christmas
Dave.
Old 06-09-2004, 04:16 PM
MadMac
MadMac's Avatar
Fucking hell yeah!!!
I assume it will only be compatable with Webber management systems? Cus I soooo want a system like that in the cab, been holding back on making a decision on the management untill I find out what the add-ons are like.
Old 06-09-2004, 04:18 PM
cossymad
cossymad's Avatar
Yep sounds the nuts......but I am not sure I really want to know what my engine is doing (to scary )
JAP CRAP
JAP CRAP's Avatar
Location: *PF TERRORISTS CARTEL* Bin flocking Youngens :cry:
you big bufty
Old 06-09-2004, 04:19 PM
zvhturbo
zvhturbo's Avatar
Thats dam cheap.
But i don't have Marelli management.
Old 06-09-2004, 04:21 PM
Darrone
Darrone's Avatar
I take it this is just a different sort of SECS Monitor??
If so, do you have any pics?
Old 06-09-2004, 04:24 PM
Pics ive just taken for you hard to fookin please lot
(Sorry for using your car Paul, but at least you now know ive deffo been doing someting with it today... )
Old 06-09-2004, 04:25 PM
gurnE
gurnE's Avatar
Whu have you hooked it up to Noddy's car??
(and when did big ears fit the YB? )
Old 06-09-2004, 04:26 PM
peteh
peteh's Avatar
Darrone
Darrone's Avatar
Bit big init! Where the hell would I mount that!
Old 06-09-2004, 04:27 PM
Darrone
Darrone's Avatar
Could you tell me the dimensions please??
Old 06-09-2004, 04:29 PM
S2martin
Ex Full Price gold member
S2martin's Avatar
I would have one matey
Martin
Old 06-09-2004, 04:30 PM
Nick500
Nick500's Avatar
Stu does that monitor work with the closed loop system and the 750cc injector set up we will be using on my car? also I forgot to ask will the SECS monitor work on the same idea? if not I will probably replace it with what you are on about!
Thanks
Nick
zvhturbo
zvhturbo's Avatar
Noddy Noddy the little man with the red and yellow car.
Old 06-09-2004, 05:06 PM
markk
markk's Avatar
i hope thats not mine your wearing out there !!!
Old 06-09-2004, 05:15 PM
SECS monitor works on adifferent principle as its compatible with all software but then doesnt show faults or allow adjustments.
Its not compatible with my closed loop software currently but im working on it.
As for you being amused by the colour scheme... how amused will you be if this 400+Bhp Dax Rush pulls up next to you at teh .lights.. any lights.. in fact, anywhere?
Anyone care to work out its power to weight ratio?
Wearing out?
Testing teh product works thats all pal
Old 06-09-2004, 05:22 PM
Billabong
Billabong's Avatar
I'd say it's more akin to a Pectel Monitor than the current SECS monitor, esp. with the fuel/ign' trim..... Looks a good piece of kit - although maybe only sell the pro model to pro's ......
how amused will you be if this 400+Bhp Dax Rush pulls up next to you at the .lights.. any lights.. in fact, anywhere?
Depends if Noddy & Big Ears are in it, then I'd still be highly amused
Old 06-09-2004, 06:42 PM
Aww.. im kinda hoping Mr Huggins is going to be my 2nd pro customer
Old 06-09-2004, 07:15 PM
SteveB
SteveB's Avatar
Mmmmmmmmmmmm tempted with a bit of that..... maybe a little over kill on my stg 1 tho...
Old 06-09-2004, 08:12 PM
DazC
DazC's Avatar
Sounds interesting.
Old 06-09-2004, 08:58 PM
SPADGE
SPADGE's Avatar
Interested if i can find room for it
Old 06-09-2004, 09:03 PM
Andreas
Andreas's Avatar
Seems to do all that the Pectel Monitor does, will it display the CO-poteniometer value too? Does it need the pectel baby board to work?
Looks a bit big, what size is the LCD? Perhaps possible to mount display separately like Bill and ive done with our pectel monitors?
Old 06-09-2004, 09:05 PM
SPADGE
SPADGE's Avatar
Stu is the correctly configured chip included in the price?
Old 06-09-2004, 09:22 PM
JesseT
JesseT's Avatar
Looks remarkably similar to the monitor in my car.
Old 06-09-2004, 09:30 PM
GARETH T
GARETH T's Avatar
propper bit of kit,,, and i could be intrested in the pro model
Old 06-09-2004, 09:37 PM
scruffythefirst
scruffythefirst's Avatar
Is that rush a quadra? Any chance of a load of pics of the engine bay / gearbox mount cos I'm going to be fitting mine soon
Old 06-09-2004, 09:40 PM
Versus_Creations
Ask me a question!
Versus_Creations's Avatar
Old 07-09-2004, 12:10 AM
markk
markk's Avatar
scruffythefirst,
yes it is !!
GARETH T,
Old 07-09-2004, 01:15 AM
Dilly
Dilly's Avatar
i'd be interested in one as well
Old 07-09-2004, 07:40 AM
B19-TRB
B19-TRB's Avatar
looks good!
hhhmmm is it sensible given ppl the option to play with there fuelk & spark! I can see IMA Racing Live Map sessions already!
but my lap top is better!
Old 07-09-2004, 07:50 AM
frog
0-60 in 17 seconds (eek)
frog's Avatar
Can you tell us more about the 'correctly configured chip'. I run a stage 1, will that be correctly configured ???
Sounds too good to be true though.
Old 07-09-2004, 08:36 AM
More on the chip:
For many years, varios people have reconfigured the Marelli operating system to send out a serial datastream for use by monitors similar to teh above. probably the most common known in teh uk are Pectel of the early 80's although there are many others around europe utilising teh same system.
This monitor is compatible with this system and will work with all your Pectel systems providing the serial communications are switched on in the chip.
Folks requiring the professional version will also need to ensure their current engine software has dynamic adjustment enabled too. Also, i may not sell you the professional version unless you give me a good reason for you to require it. This is on moral grounds and to save me aggro when you call and say;
I added some spark and removed some fuel, did a topspeed run and now it runs funny.. what are you going to do about it stu?"
How does:
"ROFLMFAO" Sound as a reply?
No, the chip is not given away with teh hardware.
Old 07-09-2004, 09:15 AM
wes
wes's Avatar
Does either version have logging facilities?
Quick Reply: New product line.. whos interested...
