How low can you gap NGK 9's ???
0-60 in 17 seconds (eek)
Sorry for the lenghty post, hopefully this will answer most questions...
My cos 4x4 is misfiring under load (above 3k on wide open throttle), drive perfectly ok up to that, and even revs up if I feather the throttle.
I have cleaned all the connectors I can reach, the gap between the crank sensor and the pulley is .4mm, which I believe is ok.
Now, I have had a play with the plug gap, .7mm and I get loads of mis-fire (even below 3k), .6mm is better but still not quite right, .5mm is loads better but still I get the occasional mis-fire and hesitancy.
When I come back from a short drive, the plugs look dark which suggests that there is a weak spark (?).
Plugs 1 and 4 were more sooty than 2 and 3, so swapped them round (1 and 2, 3 and 4). Just been out for a drive and 1 looks more sooty than 2 again.
Now, is it safe to gap lower than .5mm ? Is this just hiding a weak feed the the plugs ? I don't believe the HT leads and coil have been replaced for years now
Am I on the right track or completely off my rails ???
Thanks in advance.
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
Thanks in advance.
Forgot to say that I also have put a completely refurbished head (new valves, guides and seals) which could have increased compression slightly resulting in a blown off spark if it was weak already.
.4mm is too small a gap for the crank sensor i believe! I think it is supposed to be nearer .8mm
Doubt this is the cause of your problem which could be leads,coil etc etc...
Cheers Spadge,
I'll check the crank sensor again and look it up in the manual.
I have just ordered as new set of leads and a coil.
Greg
Greg
Thanks guys, gotta wait for the bits to arrive now and re-gap the crank sensor.
Could a head rebuild increase compression enough to cause blown out spark ? I think I might have been border line before and the extra compression just is too much.
Does that make some kind of sense ?
Froq,
Keep us posted on the outcome.
I have a similar problem and have yet to find the problem.
I'd be interested to know if you cure yours...and if so how....
Coil and leads replaced, plugs gapped at 6.5mm, still had a slight misfire on boost at high revs (4500 odd).
Thought, oh well, I'll just re-gap at 6mm and see how it goes, then this happened !!!
https://passionford.com/forum/viewtopic.php?t=71820
I guess I won't know what the misfire problem was for a while now.
