I Want.......
#43
Will be good to see how much of a difference your cam timing will make to the lag as its something not a lot of places spend that much time on.
Think my UT t38 is a special build aswell, it has bigger wastegate washer and the internals have been polished up a bit to aid flow. Ive not got a clue what sort of boost AVA plan to run it at ,will just have to wait and see what sort of power it makes when the mapping starts. Im hoping that they can keep the lag to a minimal with cam adjustment but with my cams that might be hard, as there more a top end power cam.
#44
Football Cwazy
Defo be good to see what you can acheive...what cams do you have? i beleive the closest equivalent to mine would be a BD16+......
keep us informed
keep us informed
#46
what chip do you have at the moment col?
but new set up is evolution chip written by stu to my compression spec etc on level 8 closed loop,im looking for improvments when idleing and drivability
and bucket that k n trumpet soon as,id like to get another look at the ducting colin done to your airbox euan,just to give me an idea
#50
saff is working!!!...atm
Bud-weis...u say ur maxing out greys...what spec is ur head??? and i dont know how special...
my turbo is but its got a t4 wheel and bored out ex. housing....
#51
Football Cwazy
my turbo is but its got a t4 wheel and bored out ex. housing.... ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
the greys were fine when the engine was brand new,but as it's loosened up it a bit it seems to be wanting more fuel,and even with 4.5bar fuel pressure we can't get more than about 1.9bar held safely,so i think the greys i have must be a slightly low flowing batch,or maybe there are some other issues with voltages? although nothing stood out.....but it'll a be fine when the 1000cc's go in
#53
#55
Football Cwazy
#58
you can get 'off the shelf chips',but ultimately a live map would be better ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
