Battery powered impact guns
Originally Posted by rssteve
im sure someone tested these a while ago and they would not undo a wheel nut, then the battery will probably run otu half way through.
pmsl at bars
i bought one off ebay about a year ago thought it wouldnt be very good but i was wrong best tool ive ever bought use it loads even took the rear hub nuts of with it on my cossie . i got the rolson 24 volt one from tardis tools you wont regret it .take wheel nuts of with ease
Originally Posted by Shings
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ih=012&sspagename=STRK%3AME WA%3AIT&viewitem=&item=220068503449&rd=1&rd=1
Like that Tony?
If it has your seal of approval I'll have one.
Jake
Like that Tony?
Jake
always used no matter what the job, wheel nuts can be a bitch sometimes though, but wheel bearins are not aproblem etc, and even undone my bottom pully of teh cossy aswell
duno what i would do with out it
I've got the 18.5v [i think] snap-on one, comes with 2 batterys and a charger, only take a hour to recharge and batterys last fairly well aswell, i haven't come accross something it won't undo yet, that includes subframe bolts, crank pulleys, flywheels, hub nuts etc etc!
Deffo well worth the money, even if it was £550 iirc.
Originally Posted by CraigoScott
excuse my ignorance but are these just for taking wheels off or can they be used to do other things??? :P
Not much use for robbing post offices with tho
I use a Snap On one which is great but it was mighty expensive, it will undo nearly anything though
Seen quite a few rally cars with the Sealey ones strapped in the boot so they can't be bad either, and at less than half the price of the Snap On one they sound like a bargain
Former Sponsor
the batteries split in two on the snap on ones and the contacts inside snap off very often,try getting a second replacement battry,life time warrenty my arse,sealy is the way to go.
My Snap On one has been fine for yrs
The Rally team I know of though use Snap On everything except their impact guns so maybe they have found the same problems you did Tim
I wont replace mine till its broke, which tbh I hope doesn't happen.
chap on ebay tooltimeuk he is very good, he sells bluespot guns, i bought one with 3 batts and charger etc £80 and i can honestly say its a great gun, works just as well as most others ive tried
UNAUTHORISED DEVELOPMENTS
I also have the sealey one and it is excellent. A word of warning though,dont leave the battery on charge overnight (i forgot about it!),cause the casing will melt,the battery splits in two,and you spend the next day stripping your car kicking yourself cause you have to do it manually.
07-10-2015 12:56 PM
