compression struts for bigger wheels
Am I right in assuming using compression struts on the rear of my cossie can bring the wheel more to the centre of the wheel arch? (adjust castor)
I'm mainly looking to use these at the rear as I have some fairly large wheels going on soon, and by looking at the factory setup the wheel will be touching the side skirt if I was to put larger diameter sheels on.
My question is what will happen to the handling if the wheels are moved more towards the centre of the wheel arch? I have an adjustable rose jointed rear beam setup that will go on at the same time.
Do I also have to use comp struts at the front? I'm a tad confused when it comes to suspension!
Any help is much appreciated
ive edited the 1st post, meant toi say that these are for the rears. I'm putting 225/35/18s at the front which should fit no probs.
Its the 255/35/18 im worried about at the rear.
Arches have been rolled and plastic arches have been trimmed already.
I currently have 8x17s with an et16 on the back. Width wise, I dont think I'll have a problem. Its the diameter that has me worried
CUNT!
Location: BLUE PILL or RED PILL ... All I offer is the truth, nothing more, nothing less. You choose.
Re: compression struts for bigger wheels
Bearing in mind the semi-trailing arm design on the rear end of a Cossie, technically speaking there is no castor angle.
Bringing the wheel forward more in the ways mentioned above will only shorten the wheel base; it wont affect any of the suspension geometry with regards to the arms. In general long wheelbase = higher stability, short wheel base = more twitchy but more agile but to be honest I bet the amount you need to move the wheel is so small you probably wont notice any difference.
Personally I hate semi-trailing arms - absolutely ridiculous design
carnt see there being a problem with teh diameter of the wheel mate
most people run 215/35/18 and have no problems
35 bit is the how tall teh tyre is and if others are running it then you will be fine
the only problem youwill have is running sucha wide tyre, as 255 is a tad wide
Resident Wrestling Legend
where is mr rainbird when you need a right long essay explaning about rear beams then
you'll just need to twaek the settings on the rear beam if it's all jointed up anyway to get it right in the first place so i wouldn't be running mega wheels on teh back because they are just going to scrub like buggery if it's wrong and then you'll be wanting tyres on a hurry
as for the fronts you can use the copresion struts along with adjustable lower arms, coil overs and adjustable top mounts complete with a relocated arb on the front if you want total adjustablilty
thanks for the help. By the sounds of it the rose joints on my new rear beam will give me the clearance I need.
I've noticed that on the one side of the rear wheels is MUCH closer to the side skirt than the other side. I've also noticed the front right side wheel is a MUCH closer to the front bumper. Is this normal?
I've got top mount adjustables for the front, will these be OK to adjust the wheel back to the centre? At the moment the 215/40/17s are only a few mms clearance.
well you can get 18s and 19s on std sierras using std beams etc
if one side is close then obvioulsy something is wrong somewhere and you dont want to go adjusting things just to fit the wheels as it wil drive like a big
also regarding the front end
4x4 anti roll bars move the whels closer to the front bumper than 2wd
2wd are more central on the front
if its 4wd ten its normal for the front wheels to be fairly close to the bumper anyhow
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
Adam Graham
06-09-2015 06:04 AM
