cosworth turbo damper question bolting the turbo solid
can a turbo damper on a cosworth be bolted up solid to the turbo and the to the rocker cover like the bailey one but with out the rose joint bit and just have a simple adjusting rod. as I cant see whey you would want any part of the damper to flex. more info or would be nice as looking at a pic of Karl cosworth he has a turbo damper that looks to be bolted up solid but not sure thanks
Audio specialist
yes you can but you will need a spacer like a pice of ally tube or a load of washers(which looks gash) or some good washers and a smaller bolt.... just be carefull not to bend the bracket on the turbo when you do it up...
biglee
i hear what your saying but i am going to make one from scratch with stainless steel solid bar and tube a bit like the bailey one but one to suit my manifold and turbo
if I use a rose joint would it not just pivot.what exactly is the damper suppose to do take wait off or stop the turbo rocking as the bailey one looks like it will just pivot
Testing the future
as above. the std damper has a specific job to do.
others that you have seen are more turbo supports, rather than dampers to take some of the weight of big turbo's off the manifold
ok so the ones bailey sell are more turbo suport but i still cant see how it will carry any weight if its got a rose joint on it as it will pivot and pull away may be its just me need to have better look at it
Turbosystems
ok this is what i have done so far i have made a nice turbo damper /support but not sure on the end i should use ie a rose joint or weather to bolt it up solid to the turbo what do you think
Originally Posted by Ryan
the one im going to do will be mouted to the manifold flange rather than the turbo and will have 2 small rose joints to allow for adjustment.
this tubular manifold hasnt cracked before, and its lasted 9yrs.
so im just going to copy the design for mine, cant use the one that was originally used as it was design for a 2wd head and i dont have the lugs on the head to mount it the same.
Happily retired
You are trying to support a Turbo not hold it solid. Lots of temp differentials & vibrations going on, must have 'give' somewhere or something will snap/crack.
More boost Igor!
If it's any help, here's the answer I got from Bailey - I asked how it works differently to a standard turbo damper:
Hope this helps
It is designed to offer superior support for the turbo, as the standard Ford dampers wear quickly and service parts are now quite difficult to get. It mounts on three of the standard cam cover bolt fittings and comes with a pair of spherical adjustable joints to get the tension correct (instructions included). As it uses the came cover fixing bolts, these means that it will fit both 2wd and 4wd heads/cam covers, but not the later type Escort Cosworth silver cam cover.
Caraholic
I would personally modify a Bailey one to suit your application.
escort mk4 cossy 4x4
Originally Posted by lloyd
iam not sure on this,but doesnt the hanger have to move to allow for expansion of the manifold when its glowing red hot?
155lee
14-08-2015 11:21 AM
track.focus'd
12-08-2015 05:53 PM
