R.S.T Headlight prob
On sarshs s2 rs turbo the headlights have stopped working
When you turn sidelights on there fine but as soon as you turn headlights on nothing but the main beam still works
I have checked all fuses etc and even tried a different stalk but still the same.
So does anybody have an idea what will be causing this or should i just get a auto electrition out?
Could be a bad earth (although it's not common on RST's)
Check all the connections & to eliminate the earth problem connect an earth wire direct from a good earth point on the car body to the earth in the bulb holder & see if that sorts it out
Ok this is almost definatly what it is
there are 2 of the smaller type relays at the back of the fuse box giv them a wriggle and u should see some light.
they are prob melted i used to have this quite a lot on mine but it would be when u were driving at night so plunged into darkness
if no joy get a disposable nail file and cut it down so u can file the contacts a bit as they're probably corroded
HTH
let me know how u get on
Mark
HTH
Mark
Happened to mine all the time was not the earth - used to not work if you wiggled the actual plug that plugs onto the bulbs they would work again but was very temprimental -Dodgy old shit melted connections - Cut mine off and replaced them in the end
On all 3 of my escorts Xr3i's and Rsturbo's it has been the light stalks,everytime.
Exactly the same thing
Find another from a scappy,plug and play and away you go.
its deffo the realys in the fuse box! mine does it all the time cause the pins are damaged, try wrapping a small bit of wire around it to make a better connection, worked for me!
Steve Escos
01-10-2015 06:57 AM
