My 2 wheel drive boost problems
Right some of you will remember that a few weeks ago I fitted my stage 1 chip (superchip) and a -31 actuator. On a brief road test the other week I was concerned that I was getting at least 1.2 bar of boost in 2nd gear and backing off
The car has now been sat on my drive for 3 weeks while I pondered what was wrong and I even put it back to standard briefly.
Last week I refitted everything as I was told to and I'd been waiting for a dry day to road test the car. Tonight it wasn't raining so I jumped in the car and went for a drive. I drove off boost until it was warm and then gently accelerated in 3rd gear but the boost was very quickly shooting round to 1.5 so I backed off again instantly
I've checked my amal valve and the restrictor sleeve is still there in the middle port (I think) and it doesn't look like it's been messed around with.
Please can someone please and explain to me what's going wrong here because I am trying to get the car close to what it can be so that I can get it checked over and set-up this saturday.
Thanks
Thanks
Hi,
What is the boost pressure recommended for the chip, and are you still
on the std injectors as for most stage ones chips and map sensor 2,bar.
As you also have a -31 actuator, have you set this correctly for the
desired boost i assume your looking for approx 15,psi or 1,bar.
Are all your boost pipes all tight, inc the pipes to and from the amal valve.
Regards Dave R.
Regards Dave R.
Originally Posted by davidreader5
Hi,
Regards Dave R.
Regards Dave R.
get it set on the rollers...
Originally Posted by xr4x4rs
as soon as it goes to 1.2 bar do you back off straight away?
if you do then it could just be boost spike and onec settled wil give you the 1bar your asking for
carnt remember if i asked you or not
Originally Posted by SPADGE
There should be 2 jets in your amal valve and not just one!
Thanks
Paul i havn't got an Amal valve in front of me but from memory there should be one in the port marked 'R' (return to airbox or atmosphere) and one in the port marked with a 'W' (wastegate actuator). Can't be certain but am 90% confident.
Another thing.
The correct way to check boost levels is in 4th gear. Get into 4th and about 4k rpm 'off boost' and floor the throttle and note the reading at that point on your gauge.
ok
i still think you seeing boost spike
mine boosts to 25psi and holds 22psi
so it will spike and then settle
if it stays at 1.5 bar and doesnt move then the boost needs turning down
I did try 4th but not at that sort of rpm and again the boost shot up, it produces boost easily I must say
Paul if someone drilled one out it would indeed increase the boost! The standard hole size is around 2mm. If yours looks like its been altered then that is most likely your problem but you are missing another jet.
The jet that is in there looks like it hasn't been altered but who knows. I will admit now though that I checked the 2 ports for the wastegate and turbo housing but not the return to airbox because I thought that one wouldn't make a difference. You just know I've screwed up don't you
In the morning I'll check the other one
try unplugging the amal valve?then you can see if the actuator is set too high or if its the amal valve bleeding too much. the actuator may be set to run a bar without any outside interference from the amal valve.
I haven't tried uplugging the amal valve but that was an idea I'd had
I have run a pipe from the compressor housing to the actuator and I was seeing roughly 0.8/0.9 bar
Thanks
Thanks
Thanks
Thanks
I haven't checked for cracks but I can and will I got called out for work this morning so I didn't have chance to look at the car
As standard it runs between 0.6 & 0.7 bar, it was peaking at 0.9 bar on a spike but this was due to no pre-load on the actuator I believe.
Thanks
Thanks
Thanks everyone
I'm guessing this is my problem
well it was fine before you fitted the chip and actuator yes?
id disconnect the amal valve and take it for a run see what it does
Originally Posted by Turbosystems
the restrictors are 2.5mm, one in the c port one in the r port the air box is also a restrictor
Thanks everybody for your help, I really really do appreciate it.
Thanks for confirming that. It looks like one of the previous owners has removed that and not replaced it It's been causing me a right headache and now I have to find a replacement
same restrictors in an erst amul valve
Can I just confirm that the restrictor in the return port from the amal valve to the airbox is the same as the white plastic one in the port for the compressor housing please?
Thanks
yes it is the same, when you have put one in the R port and you have set the actuator with half a hole of preload if you dont have enough boost you can enlarge the hole in the restrictor on the R port.(small amount at a time)
Spot on, I'm already running half a hole of preload I'm getting a new restrictor made up tomorrow evening by a guy local to me that knows his stuff
Hopefully it'll solve the boost problems for once and for all I can then get it checked over on Saturday
I've got some needle files ready and the guy at the rolling road has small drill bits too so fingers crossed we can get it sorted. I'm glad I discovered this before I turned up at the rollers. That would have been a waste of everyones time.
What actuator were you running and with the restrictors in place what boost did you initially see?
**update**
I got another restrictor last night and fitted it into the return port of the amal valve.
Today I took the car to be checked over and on the motorway it was already sitting at just under 1 bar of boost before we'd even adjusted anything It was still blowing the spark out on the road though.
On the rollers the car was run up and it was good all the way through the rev range and luckily it wasn't lean. The car wouldn't misfire on the rolling road which is typical.
On the way home the car is still blowing the spark out and missing under boost even though I've gapped the plugs down to 0.6mm. Time for a group A coil to try and cure that little problem I think.
Thanks to everyone for their help in resolving this
was the roads wet at all?
as it could be water getting on the dizzy
but glad to hear its sorted now
It's been along time but it's so good to be driving it. I even gatecrashed an evo meet today on my way home
Spot the cosworth
Spot the cosworth
with regards to the water
everytime it was raining my car used to misfire and i was told it was down to the dizy getting wet as theres not protection for it
how true this is i dont know
but does make sense when you think about it lol
Hopefully I'll have a group A coil soon and I'm going to go around under the bonnet checking all of the vacuum hoses and putting clips on them to make sure they are tight to try and bring the boost spike down. With the new coil that probably won't matter but for now it's too much I think.
Spot the cosworth
Paul you should of said i would of popped down and parked next to ya
Fair play mate
Good old Ace Cafe
It was a spur of the moment thing. I didn't think I'd get down there before the meet ended but the car was already done before I got it to the rollers
I don't need you parking yours next to mine at the moment it looked grubby enough as it was
