Blue thunder is dead :(
#41
Marco...if i remember rightly...when i first met you at A1 Rally you car had a knocking noise...was that the valve hitting piston very slightly then?As it hadnt that long been rebuilt had it
#42
Proven Legendary Status
Originally Posted by marco polo
I'm getting Steve Scott to rebuild the whole engine thats new pistons...
Genuinely intrested? was it cost? timetable?
#45
no worrys, I asked martin to have a look at it but he was to bizzy at the time because he had to get Porkies car ready for national day , so i phoned steve and asked him go he have a look at it
he said yes bring it down no probs ........so steve rang me and said come and collect your car on staurday it's ready so i went down to collect it and stayed there most of the day
The car was running mint on all 4 and left it ticking over for about 20 mins no probs i then asked steve come on lets go for a spin , so as we were about to move off it started to run on 3 cyl again , then made a knocking noise . Steve said that does not sound right , so we took the cam/tappets out to see if we droped a valve but it never , so it was off with the head and thats when we saw the problem
in all fairness there is no point me taking the car to birmingham(reyland) or to peterborough(scs) my engine is nothing special it a normal 400 build when steve can do just as good a job as them if not better
in all fairness it is a havry engine but has been rebuilt once due to a fuel pump failer which was no fault of harveys
which Martin did fit a new piston in it and new bearings while it was apart
Ima
when i saw you at scottys that time , that noise you heard was the Cosworth racing pistons that go like that after a good few thousand mile the noise goes away when the engine is very warm
Tony
you were right mate about fate thingy don't worry i wont be going jap at all allthough i do like the evo ........but if tune that.. they will break just as bad as the fords and more exspensive to fix theres something about the old fords i just love'em
matt
no worrys i know it was a bizzy day for you lot
thanks marco
#53
Lee
LOL.. i never have any luck with that shed ,and it's not as if i cut any corners doing it either fooking sheds
takin a break for a while.
see you next year
rob
#56
Originally Posted by 4x4pete
marco will will she be 4x4 WRC spec like steves I could see u loved it shame it didnt have full power dont be driving over 90 when u get it back
pete
steve's wrc is fooking awesome i enjoyed thos few laps proper car and he can pedal too the old bungle can
you know what, that is the only type of escort i would have if money was no object ,
don't worry i will be doing the speed limit when i get my car back
sunny
its ok when it running
Markk
yes your right it's just going to be a freshen up build there not that many events from now on really , there will be a good few at donnington tho
did you enjoy croft yesterday i did see your car out there but i wasn't sure at the time if it was yours or not what did you think of the track day they are ok arn't they ? i'll get geting it check over aswell i'll be fitting some rear Ap's to it aswell for good measure
rene
cheers son
Rob
sorry to here your giveing up the cossie mate well i'll se you next yr anyway
cheers peeps
#58
marco polo,
Markk
Markk
watch for over braking the rears m8, ive had 4 pots on the back before , have bias pedal box , even had to put a pressure reducer in to try and stop the backs from locking , it didnt work , was great until you pressed the clutch in then the backs locked like a good en !! i had no braking issues at all on sunday , in fact i would say outof all the diff braking setups ive had on this car ( incl 6pots up front and 4 pots at the rear ) this is defo the most balanced and efficiant yet , never let me down and not expensive at all !! goodluck m8 !
#59
Mark
well to be honest i don't know if the AP 4 pot on the rears are going to work or not
I have the AP 6 pot and 356x36 mm none floating on the front i was planning to use the AP 4 pot with 330x32mm on the rear... i have bought the AP bias valve the one with the lever type 7 postion
i'll try it if it doesn't work then , i can always sell this kit and buy a 315 ap kit
I do like the rally AP racing rears but i couldn't get hold of any at the time
Marco
Marco
#60
Mark
broms having similar problems at the mo with overbraking the rears , speak to him when he sorts his m8 !!
