throttle body kits for 2.0l zetecs
can anyone tell me where the best place is to purchase these and get them fitted too?
its for a 2.0l mondeo and a mk6 escort with a 2.0l mondeo engine in
cheers
cheers
Retro Ford do a full kit with an Emerald ECU & Jenvey Bodies for about Ł1400 but give them a ring to confirm that price 01536 747968
If you want something different, give Troy at Northampton Motorsport a ring (01604 766624) as they do the Titan Motorsport Roller Barrells which they've fitted to a few cars now and had some really good results.
They are also dealers for Weber Alpha & OMEX and have a rolling road so they can install and map the bodies etc for you.
Hope that Helps
Hope that Helps
now that looks a bit tastey did you get imported over from holland if so how much was it all inc
and can you take it anywhere to be fitted
if you are Interested I have my 45mm jenvey throttle bodies off my 2.1 zetec for sale come with manifold, throttle cable, linkage, 330cc injectors, fuel rail, pipercross filters and a webber fuel pressure reg. Pm me if your interested
Hope that Helps
Hope that Helps
That is supply only I'm afraid.
If you want fitting etc then ring Troy at Northampton Motorsport, they will fit them and map the car for you.
01604 766624
www.northamptonmotorsport.com
Problem is when you get there and you have it all done and then you look at the suspension alignment stuff and its an easy way to blow the rent money.... but have a superb drive home
01604 766624
thats some brilliant info there thanks again people im only just starting to research into this so im sketchy on prices etc but you have been more than helpfull
thanks again
thanks again
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
Adam Graham
06-09-2015 06:04 AM
