STEERING WHEELS
rite i have been told that if your car has airbags you cannot get insurance or pass an mot if you put a for example momo steering wheel on without air bags
is this true?
also will a mk3 mondeo ST220 steering wheel fit a mk1 mondeo steering colomn
any helpon both of these would be appreciated
is this true?
the mot is fine as long as the air bag light comes on then goes off when the ignition is turned on , to get this to work you need a resistor to confuse the check that the airbag is still there
insurance should be fine
not sure about the mk3 / mk1 bit
hope this helps
hope this helps
unless the law has changed in the last year yes , i had a removable wheel on my escort cos and that went through its mot a year ago with it , most auto electricians can solder the resistor in for you and all should work
Adam Graham
Sep 6, 2015 06:04 AM
